i have a 2002 civic auto tht i converted to 6 speed rsx type-s everything is wired up but the shop is tell me the ecu is gettin no power. can anybody help me with this problem.
Blown fuses? Does your fuel pump prime? Do you have 3 solid engine grounds? If not, connect grounds and try again. If that does not work, check power to the main efi relay below the glove box.
i have the czr at my performence shop they have everything wired up everything is ground. they have installed the sub harness and immoblizer bypass. but when they go to start the car nothin happens. They told me that the ecu is getting no power to it. I have done lots of research on this but cant find anything or anyone with the same problem. also my 02 civic ex was auto and i converted it to a k20 manual. is there anything if anything i need to do different.
you need the clutch pedal switch. i'll give you more details on how to wire this up when i get home with pictures. its basically when you have to press the clutch in to start the car on a stock MT.
edit: just saw that tuner pointed you in the right direction. you dont need the full dash harness. but i suggest getting the MT ECU subharness.
I read somethibg similiar earlier on but I forgot where...make sure no fuse is blown...the guy used a volt meter nd realized that he wasnt getting any power from one of the wires,or whatever he check I forgot...did it make any noise at all ...maybe not gettibg enough fuel
well i did the k20 type-s swap. i ve been looking an dlooking tryin to help out the shop lol. its done juss wont fire and im goin crazy cuz i want to drive this bad boy lol
Dumb question, did they ground out the wires under the dash? Theres 2 wires you have to ground out off the fuse box in order to get the car to start when converting from auto to manual. That's assuming you kept the auto dash harness.
ok juss tlked to my dude at the shop. the fuel pump is not priming from wht he can hear it not. He did tell me the key did get stuck but no it come out. the car knos its in park.
if im going from auto to manual do i need to use the manual dash harness or can i use the auto harness? main relay has been check its ok. but still no power to the ecu at all. they think it could be something in the wiring.
Or it's quite possible they didn't disable the immobilizer in kpro.. It's easy to do.. Check the ECU fuse in the engine bay fusebox. I fought with mine one for about a week. I could've sworn I had checked that fuse.. Well... a walbro later and checking relays.. the fuse was blown.
They did ground the two wires. They installed the sub harness to plug up to the ecu.
If u can u still show me them pics might help. But i know for sure that they did tht.
Theres ur problem man kpro would have saved u a ton of trouble....another thing maybe that engine harness is not good....a guy on k20 bought an engine harness but the seller gave him the auto base harness instead
thats why im thinking its either the ecu is fried, problem with wiring they did on harness or immobilizer, or the key/clutch grounding.
Related Threads
Honda Civic Forums - 7thGenHonda
posts
862K
members
16K
Since
2006
A forum community dedicated to Honda Civic owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more!
