21 - 37 of 37 Posts
Discussion starter · #21 ·
They did ground the two wires. They installed the sub harness to plug up to the ecu.
If u can u still show me them pics might help. But i know for sure that they did tht.
Discussion starter · #25 ·
Or it's quite possible they didn't disable the immobilizer in kpro.. It's easy to do.. Check the ECU fuse in the engine bay fusebox. I fought with mine one for about a week. I could've sworn I had checked that fuse.. Well... a walbro later and checking relays.. the fuse was blown.
They did installed the immoblizer bypass on my car
Theres ur problem man kpro would have saved u a ton of trouble....another thing maybe that engine harness is not good....a guy on k20 bought an engine harness but the seller gave him the auto base harness instead
wouldnt ecu still get power. because harness from dash plugs into ecu. i would also want to know what conversion harness did he get
Discussion starter · #32 ·
ok huys got somw goods news today... they called me and told me the motor fired up. The problem was that hasport wired up my harness weird. they move the power wire so when they plugged up the sub harness the pin was missing so the ecu was getting no power. so im good to go now.
:tup:
:coffee:
Discussion starter · #37 ·
ok good news motor fires up but when you rev the motor it dies out. they are still trouble shooting the problem. Hasport re wired my motor harness for a manual swap not for a auto to manual so some pins in the harnes dont plug into anything. so they are gonna try and get a un touched rsx motor harness.
21 - 37 of 37 Posts
