41 - 60 of 128 Posts
so I was going to do this swap and I pulled me cluster out (02 EX). To my surprise when I pulled it out and looked at the pig tails I found that my car is already pinned exactly like the diagran above for the 04 VP. Seeing as how it already matched the pin diagram I figured I'd give it a try (going on the theory that if my wires and clip already match the pin diagram for the 04 I should be able to direct swap). as you can guess at this point, my car worked fine, but the cluster did nothing. So my question is does someone have the pin diagrams for an 02 EX and then for an 04-05 EX. Or if anyone knows why my wiring is already set up like an 04 VP, but won't light up the 04-05 cluster that would be awesome.
You're wiring is set up under 04VP for your old cluster but since you are getting the 04-05 cluster, my theory is that you will still have to repin it according to the 04-05 EX pinning..well, try it and see if it works :x:..
On the other hand, I just did mine and the wires on my car are soooo faded that i can't even tell the difference between white/pink/yellow...lol. but i got it working money good.
This DIY is very good...:tup:TWO THUMBS UP:tup:
quick question... by getting a new cluster with lower miles than your car... after you install it does it just add up from whatever miles is on the cluster? i.e New cluster 92k old 98k.
just wondering how it all works out. thanks!
nope from what I've been told your cluster will read what ever was last on there when it was pulled. so if ur new one is from a car with 100K then when u install it in ur car u will now have 100K miles. then if u ever went back to your old one, it would read still read what ever your final miles were before u pulled it out.
there is a way to have it re flashed I guess, but it costs bank at honda.
my old cluster said 285000 kms, new one said 86000 kms, might like to try to sell it, but i think karma would bite me hard
you can get a sticker from the dmv or at a certified shop saying you installed it and the mileage is something different and it goes in your door jamb. at least you can here in nc.
also, after swapping my guages, my fuel needle says i have nothing, any ideas? everything is plugged in correctly. :dunno:
either u touched the needle and it's stuck (they are pretty sensitive from I've been told although now that I think about it, you shouldn't have been inside the cover area with this DIY), or you didn't wire it correctly. My guess is you left the wire out, it's not fully in the harness or you got a 2 wires misplaced, but you don't notice the other one cause it's for a system that you don't normally see on your speedo.
yeah they'll fit, reuse and repin them both, it's so easy, i just printed off the first page in the diy and had it beside me in the car. was a little nervous at first but when your sitting there just read over everything, look over the connectors, it'll come together
Mine are pinned hella weird. my 01-03 cluster is pinned just like 04-05 is supposed to be, but it doesn't operate the 04-05 cluster. at some point I'll just have to go try it again.
^^^ um Adam, that's an 04-05 2dr cluster... unless you mean this is what I got, like ur gonna install it soon with Eric.
basically the 01-03 clusters do not have led lights in them and they have 2 large center circles (tach-L speed-R) and 2 smaller outer circles (gas-R temp-L). the 04-05 are 1 larger center circle (speed) and 2 small outer circles (tach-L and gas/temp-R)
and I need to figure out how my car is wired. the only difference between my 02 ex and an 04 VP is 1 light pink colored wire. everythign else is exactly like the 04 VP in the diagrams. so annyoed with this, think I may just sell my 04-05 cluster and get LED lights.
related to the OP's question, a benefit of the 01-03 cluster is that the bulbs can simply be changed out, the 04-05 can't be.
NOOOOOOOOOOOOOOO do ur research smart ass its 03-05 not 04-05
Coupes got Red, Sedans got Blue LEDs
Hi Adam...what about the milage??? is it stored in the engine computer and will reflex in the installed??
coz i found ony guy selling his 05 cluster but need to be taken from his car and the milage is 25000 km and mine is only 106000 km so which one will appear after fixing in my car??
moreover, mine is EXI with NO SRS , No Cruse control but the 05 one is full options ..so i just will deattach these wires ..right??
