1990 LX 5.0 Notchback 112k on the clock
Current Setup
K&N Cone Filter
B303 Cam
BBK Shorty's
Pypes Catless X-Pipe
Pypes 2 chamber mufflers
2.5" pipes
17x9 Cobra R 4-lugs
Fluidyne Electric Fan
Triple Core Aluminum Radiator
B&M Shift Kit
MSD Cap and Rotor
Ford Racing 9mm Wires
Here are the plans for now:
ENGINE PARTS
Ford 460 BBF Long Block
FRPP Rear Sump Pan w/ Pickup
FRPP 460 Swap Mounts
Edlebrock Performer 460 Aluminum Intake
750CFM Demon Street Carburetor
Engine Machining
Engine Balancing
460 Headers for Fox Body
Speed-Pro Hypereutectic Pistons (Near flat at .065in piston volume)
COMP 268H Camshaft
COMP Cams High Energy Hydraulic Lifters
MSD Ready to Run Distributor
PRW Aluminum Water Pump
Ford D6VE/D0OE-A “Football” Rods
ARP Cam Bolt
ARP Balancer Bolt
ARP Main Cap Bolts
ARP Rod Bolts
ARP Head Bolts
ARP Engine Bolt/Accessories Kit
ARP Oil Pump Driveshaft
460 Felpro Gasket Set
King Main Bearing Set
FRPP Cam Bearing Set
King Rod Bearing Set
Professional Products PowerForce Harmonic Damper
Summit Racing Double Roller Timing Chain Set
Proform Brass Freeze Plug Kit
TRANSMISSION/SUSPENSION PARTS
Ford C4 Transmission
B&M Shift Improver Kit
UPR/Granatelli/QA1 Tubular K Member
1990 Mustang Manual Steering Rack
Ford 351M/400 Bell Housing (PN: D5OP-7976-BA)
FRPP 3.73 Ring and Pinion Kit
Current Setup
K&N Cone Filter
B303 Cam
BBK Shorty's
2.5" pipes
17x9 Cobra R 4-lugs
B&M Shift Kit
MSD Cap and Rotor
ENGINE PARTS
Engine Machining
Engine Balancing
COMP 268H Camshaft
ARP Cam Bolt
ARP Balancer Bolt
ARP Main Cap Bolts
ARP Rod Bolts
ARP Head Bolts
