Spring rate conversions kg/mm to lbs/in
This conversion rate is close as possible! It is just something for you guys to be able to gauge what spring rate is best for you style of driving and what suspension you should choose!
1lb = 0.45359237 kg
1in = 25.4mm
.45359237 / 25.4 = .017857967322834645669291338582677
1lb/in = .01785 kg
kg/mm to lbs/in
Green area: Street Use or Daily Driving only (Do not drive all the way slam down)
Blue area: Street and Track on weekend (You can slam car down)
Red area: Track only (Too stiff for daily driving)
2.0 = 112
2.5 = 133
3.0 = 168
3.5 = 196
4.0 = 224
4.5 = 252
5.0 = 280
5.5 = 308
6.0 = 336
6.5 = 364
7.0 = 392
7.5 = 420
8.0 = 448
8.5 = 476
9.0 = 504
9.5 = 532
10.0 = 560
11.0 = 616
12.0 = 672
13.0 = 728
14.0 = 784
15.0 = 840
16.0 = 896
I found this on another forum. I hope this will help you guys choose what spring rate is best for you style of driving!
1lb = 0.45359237 kg
1in = 25.4mm
1lb/in = .01785 kg
kg/mm to lbs/in
2.0 = 112
2.5 = 133
3.0 = 168
3.5 = 196
4.0 = 224
4.5 = 252
5.0 = 280
5.5 = 308
6.0 = 336
6.5 = 364
7.0 = 392
7.5 = 420
8.0 = 448
8.5 = 476
9.0 = 504
9.5 = 532
10.0 = 560
11.0 = 616
12.0 = 672
13.0 = 728
14.0 = 784
15.0 = 840
16.0 = 896
