Rear Speakers not working
1 reading
19K views 5 replies 6 participants last post by  Openmynd
#1 ·
I have an 02 Coupe Ex, with an aftermarket headunit now. But the rear speakers never worked with the stock one. I've checked all the connections but nothing to avail. How do I check to see if they're blown? Anyone have any suggestions?:pisschair:
#5 · (Edited)
Not necessarily. Voice coils can lock up and then they are silent.
As for BOTH rear speakers being stopped working, here is what I recommend: Check the wiring with a Digital Multimeter (DMM). If you are unfamiliar with them, here is a crash course.
Take the radio out. Unplug the harness. Take the red lead and attach it to the positive wire for the right rear speaker (purple wire). Take the black lead and attach it to the negative wire (purple w/ black stripe). Set the DMM for ohms, the upside down horseshoe looking thing, or Omega. Should see approximately 4ohm. Do this on the green wires as well. Should also be 4ohm.
If you get 0ohm, select the continuity setting on the DMM. Looks like this °))). Put to the purple wire, and then touch the other lead to rim of the cig lighter socket, or another good ground. If it beeps, you are grouded out somewhere. Check the wiring all the way back and fix. If not, then something is wrong with the wiring. If that is the case, run a set of speaker wire to the speaker and test to see if it works. If it doesn't, get new speakers.
#6 ·
Did this ever get resolved? Im having the same issue with my 04 civic I got a few months ago. Came with a pioneer bt unit and swapped it out for a touch screen. Sound in the rear didnt work on the old unit either but i just figured it was the mess of wires behind the dash on the old pioneer l. Installed the new unit with new speakers and still no sound! Any ideas? I checked all connections from behind the headunit to the speakers themselves. I really want to get my sound working in the back. Any help is appreciated thank you!
If you get 0ohm, select the continuity setting on the DMM. Looks like this °))). Put to the purple wire, and then touch the other lead to rim of the cig lighter socket, or another good ground. If it beeps, you are grouded out somewhere. Check the wiring all the way back and fix. If not, then something is wrong with the wiring. If that is the case, run a set of speaker wire to the speaker and test to see if it works. If it doesn't, get new speakers.[/QUOTE]
