The stock muffler has broken off the car last week, was quoted approximately $350 for a new muffler. If the car was stock I would consider it, but since I have Stage 1 cam installed I see this as a good opportunity to swap out the header and exhaust system to gain power from the cam. See build thread below to see mods done to the car.
Build Thread:
http://www.7thgenhonda.com/forum/showthread.php?t=29962
My goal here is not maximum top end power, but in the mid rev range. Defeats the purpose of the cam I know but I want power that can be used when cruising the highway.
Here are some guidelines for header/exhaust setup:
-Must pass emissions in the state of MA (catalytic converter + resonator).
-Looking for quiet exhaust since it sounds like crap with an automatic.
-Muffler needs a stockish look, do not want 3"+ diameter opening.
-Need pipe diameter ideal from beginning to end for max torque in mid rev range.
-Made from stainless steel since I deal with snow and salt in the winter.
Per the guidlines I provided, is there an ideal exhaust set up you would recommend? Would I be better off going for a custom exhaust? I am aiming for best bang for the buck here.
Build Thread:
