221 - 239 of 239 Posts
Rsx sides do not fit they are too short...
on a side note anyone know if rear rsx type s spindles will work.. i know base ones do but will the type s fit.. i know on the front end type s wont work because of the hub and half shaft.. any idea about the rear??
the rear works
Looking for a factory lower profile spoiler (but not a flush mount / deck lid spoiler), wanting to know will the factory wing from a EG, EJ, or DC fit on a EM2? I'm almost sure that 3G Integra spoilers will fit as some people have put the Type R wing on.
I've searched, but most results are either for RSX S, Type R, hybrid, etc. spoilers on a coupe. I think the ES1 spoiler will fit, but since the angle of the trunk is diff than the coupe, it sits a bit higher on the EM2.
Confirmation and / or pics on this would be great, thanks.
Great thread, and it has answered a few of my questions already. However, I'm in the process of replacing both bumpers on my 2003 ES1. I know that the rear bumper is interchangable from 01-05, but what about the front?
Will 04-05 ES front bumper fit an 03 ES, or would I also need to change the fenders and headlights too? Would it be too much work, or just stick with an 01-03 ES front?
You VTEC...I-VTEC
you have to do fenders, lights, and possibly core support(not 100% sure)
and they are direct fit? i found a cf one for the 2000. think itd work? http://www.ebay.com/itm/99-00-HONDA...:2000|Model:Civic&hash=item3cc654c75d&vxp=mtr
i hope this guy didnt try it...you have to stretch the 00 type-r lip to fit. last time i checked stretchiness is not a quality of CF
OK, thanks! Sounds like more work than I want to do. Front bumper is cracked and I want to replace it, so I'll just stick with 01-03. Just trying to get my ES1 back in top shape.
You will have to use endlinks for an EM2, the endlinks for the rsx are a little different length and point in a different direction, i found that out when installig an rsx bar on my 05 em2.
Sent from AutoGuide.com Free App
Actually, as I found out from a member on the forum, you can use rsx end links, just switch the sides. Put the left one on the right and right one on the left. The rsx end links are shorter though but they will still fit.
hey, ive done a lot of lurking and notice lots of ep3 and rsx parts fit and even the 99-00 lip on 04-05. but ive never seen a thread that was pretty legit and covered lots of parts so here ya go.
so i want to start a list of what parts from other cars work with ours.
please be specific on year and model as the slightest difference can direct someone down a wrong path and wasting $$$$.
DC5 parts
DC5 bushings will fit on em2 mugen and energy bushings.
DC5 cluster will fit on em2 http://www.7thgenhonda.com/forum/showthread.php?t=6992
DC5 front seats will fit on em2 with missing bolt or modification for 4th bolt
DC5 Buddy Club Short Shifter will fit on em2
DC5 NRG Carbon Fiber Hood Dampers will fit on em2
rsx/DC5 dash slight modification but a real good
DC5 side markers will fit on em2 and es1/2
Spoon/cusco Front Strut Bar - made for the DC5 will fit EM2/ES *****mugen bar will also fit but it requires cutting notches in the framing of your hood. cinaibar and sniperscout have it
D3 Designs Double X-Brace - made for the DC5 will fit EM2/ES
Spoon/cusco Rear Strut Bar - made for a DC5 will fit EM2/ES
Comptech 22mm Sway - made for a DC5 will fit EM2/ES
5 lug conversion, front knuckle hub assembly w/calipers, rotors. Front upper control arm. Rear lower controls arms, rear trailing arm assembly w/caliper, rotors. *drum-disc..parking cable brakes & brake lines. Rsx and DC5 will fit on EM2. *please correct me if im wrong or need more or less. dc5 = rsx. be sure you get the base rsx hubs or else your gonna need custom axles fitted (hub is bigger with the type-s) (not applicable if running a k-series motor)
Rear Sway Bar. Made for DC5 will fit em2
EP3 Parts
k20/k24 engine all variations of the k20 work.
D3 Designs Double X-Brace - made for the EP3 will fit EM2/ES
Spoon/cusco Rear Strut Bar - made for a EP3 will fit EM2/ES
Spoon/cusco Rear Lower Arm Bar - made for a EP3 will fit EM2/ES
Comptech 22mm Sway - made for a EP3 will fit EM2/ES
ep3/el(canada) rear disc will fit on em2- http://www.7thgenhonda.com/forum/showthread.php?t=1756 thanks rhcp0801 :)
Ep3/Evo X shift knobs will fit on em2
EP3 seats in EM2 DIY http://www.7thgenhonda.com/forum/showthread.php?t=6497
EM2 seat rails for ep3 seats DIY http://www.7thgenhonda.com/forum/showthread.php?t=5140
rear ep3 seats fit on em2 DIY-not for the faint of heart....http://www.7thgenhonda.com/forum/showthread.php?t=6846
EP3 steering wheel DIY http://www.7thgenhonda.com/forum/showthread.php?t=2593
02-03 ep3 type-r front emblem will fit all 01-05 thanks jamesandrew58
Misc. and interchangable parts from 01-05
04-05 tail lights made for 04-05 will fit on 01-03 w/bulb modification
04-05 rear bumper made for 04-05 will fit on 01-03 no modification
DC2 type-r rear H slight modification needed but the sizes are the closest..em2=(2.5x3) dc2=(2.4x2.9)
03 cluster will fit on 01-02 http://www.7thgenhonda.com/forum/showthread.php?t=6945&highlight=cluster+swap
01-03 Hybrid Bumper will fit on corresponding years.
04-05 headlights conversion on 01-03 http://www.7thgenhonda.com/forum/showthread.php?t=7326
s2000 steering wheel http://www.7thgenhonda.com/forum/sho...470#post264470
hey I was wondering about doing 05 1.7EL (Canadian model)front end conversion, with the rad support It should work fine I think
Rear roof spoiler(not the visor or transparent spoiler but solid abs plastic or cf) from 8th gen civic si on an em2 :dunno:.does anything else aesthetically fit from that gen to ours?
