1 - 4 of 4 Posts
How can I stop my spring binding on my TEIN BASIS Coilovers? Greasing only goes for so long. I even put the silencer rubber on each spring (2 on each) from TEIN. I heard about thrust bearings, would it work? NEED HELP.
Thrust washers should fix the issue.
Just need to know the diameter inside and outside of that plate that is sitting on the spring. So I can get the right thrust bearing over it to sit there and do it's thing.
1 - 4 of 4 Posts
