I appoligze, but this would be a remix to the brake light problem thread below...
so I am asking where should i look, I got an automatic 02 Acura 1.7 EL (02 Civic EX 4DR for simplicity sakes)
first electical related problem is the reverse lights, which do not work....
checked any related fuses, and nothing has been found, the reverse lights in the trunk are brand new and assure that they are pluged securley...
so what else could it be? any clues?
Next the rear windows on the 4DR aint working neither, now the front windows work both passenger and driver work, automatic down function works for the front driver
I suspect it could be plug related problem, but dont know where it is exactly, cause the fuses all check out to be working without any problems.
any suggestions?
thanks for all your help :tup:
I had one of the wires that flex when the trunk opens break on my 05 (it was near the taillights distribution connection crimp connector)
The wire for the backup lights is in that loom for Civic... assuming EL is.
The master power window switches can give problems with intermittent and non functioning windows.
Grab a multimeter or a 12 volt test lamp to test for voltage.
