1 - 9 of 9 Posts
on my 2002 civic coupe lx, My keyless remote will lock and unlock the passenger side, but it will not move the drivers side lock.If I manually lock the door and then use the remote it will arm the alarm like normal. It is a real pain in the ass, can you guys help?:dunno:
yes, ur drivers side door lock actuator is probably bad, while inside the car doors closed, does the door lock work on the drivers side? i bet it doesnt. if it dont, i would replace the actuator, 25 bucks, its common
Yep, most likely the actuator. There is a switch in the drivers door that monitors the position of the lock knob being up or down.
So I picked up a actuator today,and Iwas wondering if the remote will have to be reprogrammed?
shouldnt, it has its own reciever
My passenger side actuator has over time gotten really slow if it sits for while. (2-8 hours) Weird thing is if you work the power lock button a few time it works fine for a while. I have to watch now because sometimes it will not go far enough down to lock door.
Ricer 4 Life!
i have some what the same problem. my driver side door locks with the key in the door but when i try to lock it from the inside the lock wont move. i kno my actuator is fine but i think its the metal rod that is connected to it all, might be the problem.
1 - 9 of 9 Posts
