1 - 20 of 20 Posts
post it: Automotive crap you didn't know you needed
[FONT=arial, sans-serif]HAYNES TECHBOOK OBD II & ELECTRONIC ENGINE MANAGEMENT SYSTEMS[/FONT] [URL="http://www.harborfreight.com/cpi/gifs/clear.gif"][/URL] $19.99
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=97331
  • Paperback guide to your vehicle's on-board diagnostics (OBD) system
  • For all car and light truck models manufactured since 1996
  • Instructions for dealing with "Check Engine" light—from reading the OBD II code to diagnosing and fixing the problem
  • Comprehensive computer code lists, including generic trouble codes that cover all models
[/FONT][FONT=arial, sans-serif]UNDER-DASH SUPPORT BOARD[/FONT] [URL="http://www.harborfreight.com/cpi/gifs/clear.gif"][/URL] $24.99
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=97023
[FONT=arial, sans-serif]This comfortable padded board makes it easy to do repairs under your vehicle's dash board.[/FONT]
  • Welded steel square and round tubing
  • Rubber foam padding for additional comfort
  • Spring-loaded lock pin for easy adjustments from 14-1/2" to 23-1/2"
  • Weight capacity: 300 lbs.
[/FONT][FONT=arial, sans-serif]Mounting plate dimensions: 8" L x 3" W x 3/16" H; 8" L x 16-3/16" W x 21-7/8" H;[/FONT]
[FONT=arial, sans-serif]CLEAN WHEEL LUG NUT CAVITY CLEANER[/FONT] [URL="http://www.harborfreight.com/cpi/gifs/clear.gif"][/URL]
$5.97
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=97374
  • Efficiently cleans hard-to-reach corners in car wheel nut cavities
  • Soap-absorbing foam sponge for scratch-free cleaning
  • T-shaped ergonomic polypropylene handle is comfortable and features a notch for hanging on wash bucket
  • Replacement sponge included
  • Fits 1-3/8" to 2" cavities and 3/4" to 13/16" wheel nuts
Weight: 0.25 lbs.[/FONT]
[FONT=arial, sans-serif]Sponge dimensions: 2" L x 2" diameter; Overall dimensions: 6" L x 4" W x 2" diameter;[/FONT]
Where the fuck was this last year! Jesus I coulda saved me alot of back aches
No shit!!! where can i get one
Rated H for Honda
Just get an ironing board and hack it to the right measurements.
some of us are fat, and i dont think an ironing board will hold 300lbs. i think if you have to major things under the dash like a clutch master cylinder its easier just to remove 4 bolts and the whole damn seat. well thats what i do at least.
thats some sweet stuff, where can i find the board and the lug nut cleaner? cuz i am fat, and i do this for a living, and i hate getting under dashes at work
I bet money on a cheap walmart weight bench... and hack it and adjust it to the right size
Discussion Starter · #9 · (Edited)
these item can be found at the national discount tool retailer.
stores by state: http://www.harborfreight.com/cpi/ctaf/retail_stores.taf
Sign up for there email specials and also have them send you their free cataloge. I thumb threw it all the time.
Good place for decent tools, no craftsmen quality (house branded name) but good for the budget mechanic
Plus the cataloge is good for reading on the can.
[FONT=arial, sans-serif]6000 Lb. Capacity Scissor Lift with Hydraulic Pump[/FONT]
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=46604
  • Raise cars or trucks 39'' to work on brakes, mufflers or wiring
  • Steel plate construction
  • Includes lift, electro-hydraulic pump, dolly, four saddle pads
[/FONT][FONT=arial, sans-serif]Motor: 220 volts, 1 HP, 3450 RPM, 6-8 amps (under load); Weight capacity: 6000 lbs.; Pump pressure: 2300 PSI (max.); Ram stroke: 13-1/2''; Minimum height: 3-7/8''; Starting lift height: 15-3/4''; Overall dimensions:79'' L x 39-1/2'' W x 39-3/4'' H[/FONT]
[FONT=arial, sans-serif]ITEM 46604-3VGA[/FONT]
[FONT=arial, sans-serif]$999.99[/FONT]
[FONT=arial, sans-serif][FONT=arial, sans-serif]6000 LB. CAPACITY SCISSOR LIFT[/FONT] http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=46604[/FONT]
[FONT=arial, sans-serif][/FONT]
[FONT=arial, sans-serif]Raise cars or trucks 56'' to work on brakes, mufflers or wiring. Steel plate construction. Includes lift, electro-hydraulic pump, hydraulic hose, dolly and four saddle pads.[/FONT]
  • Motor: 220 volts, 2 HP, 3450 RPM, 10/14 amps (under load)
  • Weight capacity: 6000 lbs.
  • Ram stroke: 20-1/2"
  • Minimum height: 7"
Shipping weight: 1076 lbs.[/FONT]
[FONT=arial, sans-serif]Overall dimensions: 99-3/4'' L x 40'' W[/FONT]
[FONT=arial, sans-serif]ITEM 91315-4VGA[/FONT]
[FONT=arial, sans-serif]$1449.99[/FONT]
[FONT=arial, sans-serif]7000 Lb. Capacity Two Post Hydraulic Auto Lift[/FONT]
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=46299
[FONT=arial, sans-serif]Lift autos and trucks up to 7000 lbs. Powerful automotive lift gives you 77-5/8'' maximum lift--perfect for muffler and transmission repair.[/FONT]
  • Electro-hydraulic system uses electric motors to power the hydraulic lifts
  • Automatic safety --locks arms in place at any height
  • Constructed from 7 gauge ASTM-rated steel
  • 3/8'' galvanized steel aircraft cables
Shipping weight: 1969 lbs.[/FONT]
[FONT=arial, sans-serif]Lift capacity: 7000 lbs; Drive-through clearance (width): 105''; Maximum lift: 77-5/8''; Minimum lift: 5-3/8''; Motor: 220V, 60Hz, 15 amp, 1 phase;[/FONT]
[FONT=arial, sans-serif]ITEM 46299-3VGA[/FONT]
[FONT=arial, sans-serif]$2079.99[/FONT]
[FONT=arial, sans-serif]they have more lifts but cost more[/FONT]
[/FONT]
Retired Mod
This man speaks the truth. The only 3 magazines I brought with me on this deployment was a Harbor Freight catalog, the Summit parts catalog, and the Summit tool catalog.
Discussion Starter · #11 · (Edited)
[FONT=arial, sans-serif]Fender Repair Tool[/FONT]
[FONT=arial, sans-serif]http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=98793[/FONT]
[FONT=arial, sans-serif]Use for fender collision repair or fender flaring, or to increase fender clearance.[/FONT]
  • Fits most cars and light trucks with 4 and 5 lugs
  • Simple and easy to use
  • Roller works on fender from inside wheel well
  • Attached hitch pin allows for wide or narrow angle
  • Adjustment arm has second telescoping arm with roller that allows for 180º wheel swivel
[/FONT][FONT=arial, sans-serif]Base mounting plate dimensions: 3/8" thick x 5-7/8" diameter, center hole: 2-3/4" diameter, 8 mounting holes: 9/16" x 1" long; Support bracket: 5/16" thick x 6-1/2" long; Adjustment arm: 2" square tube x 6-1/2" long; Second arm: 1-1/2" square tube x 9" long; Overall length: 27" long[/FONT]
[FONT=arial, sans-serif]ITEM 98793-0VGA[/FONT]
[FONT=arial, sans-serif]$74.99[/FONT]
[FONT=arial, sans-serif]Ratcheting Exhaust Pipe Cutter[/FONT] - http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=98225
[FONT=arial, sans-serif]This revolutionary tool holds pipes tight for a straight cut, handles the larger diameter of exhaust pipes. Patented design.[/FONT]
  • Suitable for thin-wall tail pipes from 1-1/8" to 2-5/8" outside diameter
  • Also cuts for stainless steel, copper, aluminum and steel electrical metallic tubing (EMT) conduit pipe
  • M2 high speed steel cutter blade
  • Heavy duty construction in a convenient and lightweight tool
[/FONT][FONT=arial, sans-serif]Overall dimensions: 9-3/4" L x 4-1/4" W x 1-7/8" thick[/FONT]
[FONT=arial, sans-serif]ITEM 98225-0VGA[/FONT]
[FONT=arial, sans-serif]$59.99[/FONT]
yup +2
only place in the world(besides ny which sucks 2) that wants 10 dollars + for a pack of smokes...
well I got something canada can smoke
Retired Mod
Nope, both the UK and most places in Europe have $12 packs of smokes. I was paying $2.50 a pack in Algeria.
dam with some of these stuff i can make a garage like a shop already especially with that hydraulic shit
BWAAAAA
<3 harbor freight.
i used to travel far to go here.
now they opened one up 5 min from my house. i live there now... im actually posting here now. im by the drill presses. :eek3:
I am not sure if I would work under a harbor freight lift tho... kinda risky imo
but I buy all of my odds and ends at that place
1 - 20 of 20 Posts
