LOL, SOLVED IT, DRL BOX WAS MISSING FROM PREVIOUS OWNER!!!!!!!!
2003 Si auto to manual swap,
Auto engine harness,
Auto dash harness,
Auto ECU,
Auto ECU transmission plug hanging,
Gear position sensor plugged in left in P
So, no high beams. Is this because the car thinks its in Park?
Whats the solution?
I changed the wires at the plug to get hight when low is selected and this worked, when I moved the switch to high the lights go out and this is the only time the high indicator on the dash comes on...
Checked bulbs and relays already.
I do plan on changing the ECU to manual when I find one for cheeeeep.
