I've decided things are getting sketchy enough(hi speed float) that I need to replace the struts on my 2004 civic ex sedan. I've always wanted adjustable damping on my car like I have had on motorcycles and bicycles for many years so that limits the choices some. I also don't like the idea of dumping thousands of dollars into a strut kit. I'm not racing, just an enthusiastic daily driver that does an occasional rally/touge run on tight Viriginia mountain roads, which sometimes get rally rough. This has led me to the decision that I don't want to lower the car much if any, but at the same time reduced body roll and torque on the stabilizers would be nice. My current thinking is Koni sport inserts(since I can't find yellows anywhere) and a ground control coilover kit that will let me decide on ride height.
It's already got eibach stabilizers which really help control body roll. I considered them a repair when I bought the car with wanky little wires they put on it for the U.S. market. Without them the car would lift the inside rear in a butt puckering sort of way on complex corners. Not something you want when braking into an off camber downhill switchback.(yikes!)
Anybody got ideas or thoughts on this, or alternative setups that won't break the bank or arbitrarily lower the chassis to bouncy skateboard level, Also, any other adjustable links or bits I should consider?
thanks.
Ray
thanks.
Ray
