J swap em2
136 views 1 reply 2 participants last post by  drewr1122
#1 ·
Hello, I’m new to threads and this community.
I’m currently in the process of installing a j32a3 with its 6speed LSD into my red EM2.
so far I’ve installed Rsx type S spindles, Hubs (5x114.3 with a 36mm axle), calipers. rotors are coming soon.
I’m just in the process of fitting the motor and the axles(j32).
From just setting the motor in the engine bay my first concerns were exhaust routing as the high mount steering rack takes up a lot of space. I have about 4” clearance from the tie rod.
I’ve got almost everything to run this motor: ecu, wiring harness, gauge cluster, steering wheel and emobilizer, drive by wire pedal and box, j32 axles and rsx type s axles in case they don’t fit, fuel pump which doesn’t fit. Fuse box.
Type S hubs up front.
