Injector size
Tags
injector size
2 reading
15K views 16 replies 12 participants last post by  Brandonm
#1 ·
Would 310cc injectors be to small to run 7-8 psi on a stock motor or would dsm 450 injectors be preferred
#2 · (Edited)
If its a D17 dont use DSM injectors. Dont use low resistanc peak and hold injectors without a standalone and I would strondly push an injector driver as well. Even with the resistor box its not the way to go. I ran DSM 450s on my AEM ems and they idled awefull no matter what anyone did to the maps. If you look around more there are other injector options on the table.
#7 ·
I dono man, I'd chock that up to the AEM, I ALWAYS had idle issues with that fucking thing. I'm running rc 1000's with a resistor box and it idles beautifully, even with the stage 3 cam. I'm not using a driver, either. According to Jeff, with my setup, a driver would be ulitmately useless. The drivers on the newer ecu's are plenty efficient to handle a p&h injector with not problems. I've had the injectors for about 6 months or so and haven't had any issues with them. I know alot of k series guys run them without drivers, as well...
But, you may be talking specifically about dsm injectors, in which case, I've never bothered with them so I can't really say either way...
#5 ·
www.injector-rehab.com/issg
Plug in your power goals, follow the rest of the instructions and that will tell you what size injectors you should run.
Key thing to keep in mind about the SRT-4 injectors is that they only flow 577cc at 54psi. At the stock Honda fuel pressure (43ish) they flow about 480cc.
#8 ·
But what about injector clips?
How do I know which ones to use?
I'm glad you asked 'foos, I'll be happy to help you with that question.
If you are using RSX-S and RDX injectors, then your stock clips are fine.
If you are using RC style injectors, then you need Bosch EV1 injector clips, like these:
Going rate for a set of four (4) EV1 injector clips with pigtails is $25 shipped on Ebay.
If you are using SRT-4 injectors, then you need Bosch EV6 connectors like these:
Going rate for a set of four (4) EV6 injector clips with pigtails is $27 shipped on Ebay.
#9 ·
What are the different flow rates for the injectors 'foos?
Another fine question. Here. Please note that Stage 1 577cc SRT-4 (OEM injectors in 04+ SRT-4s) injectors are actually 500cc injectors on the stock D17 fuel pressure.
