I realize the forum is pretty dead now, but with everyone migrating to FB and whatnot, how are people going to get info through a google search anymore?
That's going to be an unfortunate consequence of the migration. So I will go ahead and document my journey here, so one day someone may have the same problem and google it, and find my post and maybe it will help them out.
The other day I came back from a 50 mile all highway trip and filled up gas. Got 35 MPG, which is one of the highest I've ever gotten. I filled it up all the way, but the needle didn't go all the way to the top, even after the usual delay. I thought that was odd, but whatever.
I drove a few miles around town, and once to work which is mostly highway. I noticed that my gas gauge was dropping pretty fast. I filled up after 66 miles and got 19 MPG!
I scanned the car and my long term and short term fuel trims were about +7 or +8 each, which doesn't set off a code, but is high. The car drives perfectly fine, but the gas mileage is horrible. I've scanned the car with over 200K miles before and my fuel trims are usually like -1 short term and +2 long term. Really close to 0 like they're suppose to be.
Thought maybe it was a fluke, so I drove only to work the next time. Usually I get around 29 MPG with a mix highway/city. I got about 24 something the next fillup, which still isn't good because there was all highway and no traffic that day.
In case it was something clogged, I did a steam clean with water, and 1/3 bottle of B12 down the vacuum line. It didn't help.
I drove it the same 50 mile trip all highway again. When I got to my destination, I actually got a pending code. P1456. Google search basically told me it's the gas cap every time. I replaced it with a brand new Stant gas cap I had laying around. That code hasn't come back after a week. When I got home from the 50 mile trip, I got a P0420, which I know is pretty much always a cat code. I've replaced the cat twice already, I'm skeptical that the cat is actually bad, I think it's something else throwing off the computer. Code hasn't come back in a week either.
After I replaced the gas cap, it actually did change something. When I'm driving and coasting, the STFT actually does go to 0 now. But it jumps to like 12 or 18 sometimes when i put the slightest pressure on the pedal. If I come to a traffic light, or park it in the garage the STFT is usually around +8-12. LTFT is about +7.
I thought maybe it was the purge solenoid because that's related to the gas cap code. So I bought a used throttle body assembly and cleaned the IAC up and installed it. I got it cheap. So it's the new throttle body, IAC, and Purge Valve. Installed that today with no improvement.
I have a fuel pump assembly I ordered earlier this week, but it's delayed due to weather. I'll be putting that in next. The assembly wasn't that expensive, and i figure worst case scenario I get my filter changed.
If that doesn't work. I'm gonna stumped. I'll list the stuff I've done so far, and other items for reference.
2001 Honda CIvic EX
320K miles (engine changed at 140K, Head gasket changed at 180K, Head job and head gasket replaced again 5 months ago at 314K)
Automatic transmission replaced at 40K, 80K, 220K. Fluid drain and fill 15K miles ago.
Throttle Body swapped out around 210K, and again today
Fuel Pump Assembly swapped out around 210K
Both O2 sensors replaced around 217K (Denso for Downstream, NTK for Upstream)
Spark plugs last replaced last spring I think. NGK Coppers. I took them out last week. A little browning to the white porcelain part but it's been like that for a while.
Recent Maintenance:
New Gas Cap Last Week
Replaced throttle body with newer IAC and Purge Valves
Steam clean plus B12 Chemtool through brake booster line
Cleaned EGR Valve
Marvel Mystery Oil 4oz in the gas tank
Tire pressure set at 34 PSI two weeks ago right before my 35 MPG trip
Checked for vacuum leaks and couldn't find anything, but it's very very hard to find leaks. My Dad's car almost assuredly has a vacuum leak and I tried for 3 weeks to find it but couldn't. I did the brake cleaner test, but I don't even know where all the vacuum lines are. I just sprayed everything around the throttle body and the brake booster line. In my Dad's car, the fuel trims actually do go down when you're accelerating, which is a classic symptom of a vacuum leak. My car doesn't do that. The fuel trims increase very quickly when you accelerate.
Yeah, the car drives fine, and it has a ton of miles on it. But if you're on this forum you're probably the type that really takes car of their car and wants it to run optimally. And I have an emissions test next month I don't want to fail, and I don't want to do damage to my cat. And if I'm burning an extra $7 worth of gas per week, that'll add up.
I'll update use this thread for updates. I've attached some relevant pics.
2001 Honda CIvic EX
Recent Maintenance:
Cleaned EGR Valve
