Hi Guys,
I'm close to completing my ES1 Sedan 05' Auto Civic to K24a3 6SP M/T.
Im having some issues with either the ECU or Starter or both
Starter isnt engaging with flywheel. (ordered a new one)
Bench tested & starter does spin when jumped but issue still remains below:
Car is auto chassis & key is held hostage in ignition barrel when trying to take out
Ignition barrel also never has been able to turn starter motor on.
Old Engine: D17z1
New Engine: K24a3 (from accord Euro)
Old Harness D17z1
New Harness Base RSX
All ground cables in
ECU: PPA Q04 CRV 04' KPro from RevZone Aus
Error code in ECU logs also:
P1607 for ECU internal circuit malfunction check
(When I go to load up a map file in Kmanager - I dont see PPA so only other option is to go 'other engines' and select the stock TSX map)
Immobilizer is also disabled & Kmanager can talk to ECU/upload/save maps & changes
A little stumped and dont know whats causing the ECU to not turn the starter motor...
Any ideas?
Old Engine: D17z1
Old Harness D17z1
Any ideas?
