Status
Not open for further replies.
01-02 have 50mm struts and 14mm crash bolts
03-05 have 55mm struts and 16mm crash bolts
02-05 EP3's have 16mm struts, the rears will fit all year 7thgens but the fronts will only fit 03-05. If your looking at springs for an ep3 dont get them because they are heavier and will cause the car to sit uneven, coupe or sedan. If you are looking at coilovers and you have an 03-05 coupe or sedan they will work fine
There is no way to get the fronts to work on 01-02 models unless the whole knuckle is changed which is not worth it.
Status
