Hey guys!
Well I got following problem:
When I open door and turn ignition off interior lights disappear. same thing with central lock- when doors are closed and engine is running central lock is working, when I try to lock door from outside with key it doesn't work.
What I checked so far: ALL fuses are ok!!!
My assumption is that there is some kind of constant 12V power supply failure.
All this happened when my stereo died. Well, the constant 12V died... Problem was that there was some kind handsfree system and some dumbass cut all the wires but "forgot" to take the whole system out... result was that bare wires were touching metal. I removed whole handsfree assembly and found melted wire.
I replaced this damn wire and everything start to work again- for a week...
Any ideas?
I cannot find good wiring diagram. maybe somebody had the same or similar issue.
I understand that I need to supply 12V power to something but I do not know where shall I search for failure.
Any ideas?
