1 - 20 of 20 Posts
You said you dont care about the wiring, I took that as, you dont care if they turn on/off, sorry.
If you are wiring, I made my own wiring instead of using the ebay harness. I found it to be brighter using the custom harness than using the ebay one.
easy. just do trial and error. keep about 1/2 inch all around then cut cut cut till they fit.
first remove bumper...
2nd use hole saw to cut a hole then keep test fitting and then cut more if needed
then install the fogs.
and have fun with the wiring if your gonna make it just like the stock fogs took alot of trial and error.
Pro chopsticker
Use your eyes!
Just kidding...it's a little smaller than the cut out that is on your bumper. You shouldn't mess up. Cutting is EZ wiring with Switch took a little time...
i just used a box cutter and cut a hole size of my fist and then try to fit the back of the fog in, make it a lil bit bigger if they dont go in.. dont cut it too big tho. just enough for the back to go through.
1 - 20 of 20 Posts
