Hello All. Hope this comes in handy for some of you trying to remove that nasty Oxidation that can hinder the look of your rides. This is my Frist DIY so please ask me any questions that you may have when you read this.
I'm starting this from the point where the headlights are off the car. I wanted to black out the housing and pluse it makes it alot easier to do.
First I'll start with the tools:
600 sandpaper
2000 sandpaper
spray bottle w/dishsoap and water mix
Microfiber cloth
Oven
Meguiar's PlastX (Clear Plastic & Polish)
and lastly a lil bit of mucle for sanding.
First start out with preheating your oven to about 250*F.
After Preheated you are going to put your healight in for 6 min's.
with the headlight freshly hot and out of the oven trake a flat head screwdriver and slowly pry away at the pressure clips and the backhousing will start to seperate from the clearfront. ***BE EXTREMELY CAREFUL NOT TO GET THE SEALING GLUE ON ANY OTHER PART OF THE HEAD LIGHT*** it is extremely hard to remove and may cuase you more work. That Goop is pretty darn sticky.
Now you can begin with removing the Oxidation from the Clear Lense.
With your spray bottle of Soap/water solution spray the lense and 600 grit sandpaper.
Then as if you where waxing a car use a circular motion and make sure to throghly sand the front, nice and even. Make sure to keep the sanding area and sand paper wet the whole time you are sanding.
It took me about 15mins of sanding to remove all the Oxidation with the 600 grit, leaving a nice smooth fogged finish.
After you have removed the oxidation repeat this step again with the 2000 Grit sandpaper. A good rule of thumb for sanding is if you think your done keep going for about 5 more mins. After done with the 2000 grit the surface of the cover will be realy nice and smooth with a frosted finish.
Now is the time for polishing out the frosted layer. Apply the Meguiar's shine and polish to the surface and leave and even coat across the surface. Take your drill with the polishing pad that came with the Polish and buff in the polish. I used the fastest speed on my drill but make sure that your not leaving it in one place, you may leave an undesired mark and you'll have to repeat the sanding steps over agian. After the first coat is buffed in take your Microfiber cloth and remove and leftover residue.
Do this step with the Polish and the drill about Two more times.
For the Final step take the Microfiber cloth and spread a thin coat on the lense and let stand for about 5 mins. Then lightly buff the polish out until the clear finish apears:wave:.
step back and rejoice because you just saved yourself alot of money from buying a new headlight!!!!!!!!:dance::dance:
Before:
After:
Now if you have been thinking about Blakening out your Head lights, this is now the time!!! Just put a few coats of color paint of your choosing on that Chrome housing and your good!!!
When putting the Headlights back together reverse the steps of taking them apart. ***MAKE SURE YOU USE ALITTLE CLEAR SILICONE AROUND THE EDGES ARE SO YOU LIGHT SEAL PROPERLY*** otherwise you'll be driving around with condensation built up inside the lense and you have to take them apart again and dry them out. SUCK FEST:wtc:!!!!
Here are some more before and after Shots:
600 sandpaper
2000 sandpaper
Microfiber cloth
Oven
Before:
After:
