1 - 20 of 73 Posts
I love Greenie
Discussion Starter #1
This is the Link that i pretty much followed and read over: http://www.spcperformance.com/PROD_DIR/PERF_TECH_DIR/PROJCAR1/SPCPerf_PROJCAR1E.html
It's pretty much common sense, there's not too much to this DIY but i'm sure it could be useful to some.
DIY Rear Camber Kit Install
Difficulty: 1 out of 10 (1 being the easiest)
Time required: About an hour
Hardware required: None, it's all included in the kit
Purpose of this product:
To adjust the camber of your wheels.
Tools Required:
- 19mm Socket (For lugnuts)
- 17mm Socket/Socket Wrench
- 17mm Wrench (If you'd prefer that)
The Product:
The Install:
1. Loosen your Lugnuts and take off your wheels:
2. Take your 17mm Wrench and loosen the 3 bolts on the OEM camber and remove the camber:
3. Take your OEM camber kit and compare it to your Adjustable camber kit and resize the adjustable one to the same length as your OEM one. You can go ahead and toy with it until you get your wheels aligned to your liking.
Finished product:
**After you're done installing i highly suggest you take it in for an alignment**
I love Greenie
Discussion Starter #3
I don't even remember, i bought this a year ago and finally got off my ass to do it... I think they run about $80-$100 for the rear and $20-$30 for the fronts.
Very nice DIY. I have a set of ingalls that i have been waiting to install so i guess i will do that soon. What did you torque the bolts down too?
I love Greenie
Discussion Starter #5
I read it is supposed to be 43 ft/lbs... But i don't have a torque wrench so i just hand tightened.
Retired Mod
Good DIY. About time you started working on your car again.
Its pretty good, you left out a couple steps.. lol
Before you can take the wheel off you need to jack the car up.
And on the wheel side of the OEM camber, the Nut is welded on to the bar. So you need to loosen from the non welded side.
Rated H for Honda
Stock: Welded on nut.
Hardware Req: New #12 bolt and matching nut.
just a note, about hardware. the spc camber kit didnt have a welded on nut like the stockers. you either have to take the bolt to the hardware store (12x1.25) and find a matching nut. or buy a seperate bolt and nut. which is what he/we had to do. as you can see in the pics that nut and bolt is brand new shiny silver. he used locktite blue (non perm) for it, and im sure its well past the 43 lb/ft requirement. it shouldnt move. just remember if you do have to buy a nut/bolt for it thats its a #12 in size and just to get matching thread pitch. that is all.
mine came with nuts and bolts necessary to do this, thats weird urs didnt, u sure u didnt just lose it ryan?
Rated H for Honda
well in that case, it prob did. his kit did sit around for a good year. so he might have lost them.
if it does come with nec hardware lol, dont mind my post. if it doesnt, all you need is #12 size bolt and matching thread pitch nut.
x2 i got me a set of Ingalls sittn at home too, Great DIY bout time someone posted this up on here
I love Greenie
Discussion Starter #12
Yeah i'm pretty sure it was supposed to come with the hardware, i either lost mine during the move or i didn't get the hardware.
you might want to add that the upper camber arms have 2 different shaped holes where it bolts on to the body of the car where the bushing is. one is a oval and one is a circle, the oval hole on the arm has to be bolted on closest to the front of the car first then the circle facing the rear of the car last.
Well i just checked my ingalls kit that i have only opened once until today and mine has the nut and washer but no bolt. Also are you suppose to reuse the factory bolts where the camber arm bolt to the body of the car?So i dont know what that is about unless that is how the kit comes.
1 - 20 of 73 Posts
