We tried to do a good bleed on the system but to no avail... it just won't hold preasure? Am I doing something wrong or do I just need to buy a new master and slave cylinder? Should I do both?
Tried that method. Didnt work. And i have no leaks. System was working before. Just flushed it all out so i could get fresh fluid. Im basically starting with empty lines.if the pedal still falls to the floor without getting up then try this:
Pump the pedal 20 times with the bleed screw closed, does it get stiffer?
If yes, then there is air in the system and you need to bleed properly, or there is a TINY leak that slowly pours air into the system
If no, then there is a major leak(most likely the cause since you've been bleeding forever with no luck). The leak is either at the slave cylinder or master cylinder. I would recommend changing both cylinders and bleed the system.
-been there done that
