61 - 80 of 87 Posts
· Cammin'
Discussion Starter · #65 ·
i got a few more things in this week. i think i finally got some prelude rear mud guards, so now i can take the accord ones off lol. also got some jdm fogs and headlights. hopefully the weather will be ok tomorrow and i can get this stuff on.
· Cammin'
Discussion Starter · #66 · (Edited)
well today turned out to be kind of a flop. i totally forgot i would need adapter harness for the headlights. can i just run a hid kit instead or do i absolutely have to use the adapter harness? also are the hid sized h4 and h1? as for fogs i cut the holes but i cant find a diy to show how to mount them. i tried using the preludezone one i found thru google but it wasnt much help on the mounting part. i did get the accord type r lip on though and i love it.
camber?
cut fog holes
here is my mounting problem. i have great paint skills and have circled the areas in question. are the fogs suppose to mount to the studs sticking out? also i think i am missing the piece that helps mount the cover on the driver side. any suggestions?
driver side
passenger side
here is how i mounted the lip. i laid my stock lip inside of it to drill the middle holes. i took the stock lip out and mounted it to the bumper with the factory bolts in the center. this helped hold it in place while i drilled the other holes for the smaller bolts/washers/nuts that came with it.
its a little long
· Cammin'
Discussion Starter · #67 ·
update:
i got my blox knob and jtc shift extension kit on saturday. i got the fogs installed and wired into my headlights. my shift boot keeps poppin off so i drilled some holes and zip tied it. i also trimmed and installed the prelude rear mud guards so no more accord ones.
team voodoo on the left and blox on the right
accord mud guards
prelude mud guard
FOGS!!!
· Cammin'
Discussion Starter · #68 ·
UPDATE:
well i got rear ended again but this time on the passenger side. i was involved in a 6 or 7 car pile up on the way home from work on friday. luckily i didnt hit the car in front of me and i had minor damage compared to the other vehicles, mine was the only car able to drive away. i still havent found an adapter harness for my jdm headlights. passwordjdm is out of stock and so are several other sites that carry it. i did get a few good pics a couple days before i got hit.
a couple more pics of the rear with prelude mud guards installed
now for the bad pics
i need a new rear bumper and i believe this is the color code
· Cammin'
Discussion Starter · #72 ·
Update:
finally took the time to put the neuspeed bar on. that thing is a pain in the ass to get on too. also picked up a wire harness for my jdm headlights from someone on another forum, so i finally got those on too. whats the bulb size for the hi and lo beam on the jdm headlights?
jdm on top and replica on the bottom
i do kinda miss the amber corners though
messing with instagram
these were before i switched the headlights
I'm not sure aerocatch latches will be large enough to cover up those old school hood pin collars?
I accidentally cut the holes too big on my hood for the hood pins...:hsugh:
61 - 80 of 87 Posts
