41 - 60 of 87 Posts
· Cammin'
Discussion Starter · #42 · (Edited)
well i got my other stuff a few a weeks ago but i havent had time to post. i got this stuff super cheap and just couldnt pass it up.
aem v2 intake - used as a display so pretty much brand new. my factory system was broke and most of it was missing.
wasnt sure what to do with the extra hose that goes from the tb to the idle control box, so i put a cap on it. is this correct or does anyone have any suggestions?
looks so sexy and sounds amazing when you get on it
DC header - i will hopefully be putting on this weekend. i also went ahead and got a cat delete pipe as well.
also a very important tip - dont forget to remove all tools from under the hood before driving home
· Cammin'
Discussion Starter · #45 ·
on saturday my brother and i went on base to install my dc header/cat delete pipe. unfortunately my car was too low for one lift but i was able to use other type of lift. the old header and cat were done and were so rusted we almost couldnt get them off. i was not able to retain my o2 sensor so i am in need of a new one and i will probably order as soon as im done here. on my way one something came off because i have a nice leak and my car sounds terrible now. i know my cat pipe has a place for a sensor but its plugged. the downpipe is where my sensor goes and it had a plug in it as well, but i dont think it was secure. my dad and i torqued and checked all the bolts yesterday and i totally forgot to check that plug on the downpipe. so for right now im beastin it till i get a new sensor in.
i searched alot of parts stores for this gasket and still had to order it online
my torn axle
goodbye cat converter
im still not sure if im gonna keep the tow hook or not
Happy Halloween
· Cammin'
Discussion Starter · #49 ·
small update:
i got a denso sensor but both connectors are female. i went ahead and put the sensor in to plug the hole and cure my exhaust leak, but i need a male connector to wire in and connect to the main harness.
i splurged alittle and bought a Bride boot. i also got my Team Voodoo knob out of my civic and put it in the prelude since i havent gotten to try it yet. right now i dont have the boot fastened down with anything. the stapler i have wont go through the plastic.
my crank pulley broke the week before last. the nite before the powersteering quit and i thought i was just the belt. i drove it to work the next day without issues until it was time for me to go home. started it up and all i heard was clank clank clank. the pulley separated from the harmonic balancer. i picked up a Ralco set and now the prelude is back on the road.
· Cammin'
Discussion Starter · #52 ·
UPDATE:
since i dont smoke i drilled a hole in the back of the ash tray for the alpine ipod cord
i got a flat
the spare just happen to be flat too
i put the blades back on for now
i got an Apexi Megaphone Dunk muffler from a buddy and had APE put it on yesterday. it almost didnt fit cause it was pretty big, but with alitte custom piping they got it to fit. i made a short video this afternoon and put a link at the bottom of this post.
some random pics
http://youtu.be/GLd4gYkQVfg
· Cammin'
Discussion Starter · #54 ·
got a few more boxes today :yumyum:
neuspeed wires
WedsSport RS-5 15x6.5 +26 offset 13.2lbs per wheel
they need a good cleaning, but i think they will look neat. im trying to find some center caps but its proving to be quite difficult.
· Cammin'
Discussion Starter · #57 ·
UPDATE:
i got my tires switched over to the weds and with the help of a friend rolled my fenders. the rears didnt get rolled much cause we found some bondo and may cut the lip with a dremel. i also switched to the apexi ws2 and straight pipe i got. the neuspeed wires didnt fit since the tube was a bit too long and i will be sending those back. i will have to get better pics soon since ive been working a ton i try to get all the wrench in i can vs good pics.
too long :thud:
old exhaust with apexi megaphone muffler
apexi ws2
test fit
when rolling fenders i threw one of my buddies xxr's on for fun. its a 15x8 +0 offset.
· Cammin'
Discussion Starter · #59 ·
i picked up a neuspeed front strut bar today from someone on craigslist. when i got home i was gonna put it on, but it doesnt look like its the right one. maybe im just not looking at right, but doesnt it mount to the struts? thats how the neuspeed one on my civic works.
· Cammin'
Discussion Starter · #60 ·
so sunday afternoon i noticed someone pulled the old hit and run while my car was parked at my apartment. i also noticed most everyone that parks in my area has a white car. cops told me to keep an eye out for a car that may have done and give them a call. on the upside i got an accord type r lip. i did a test fit and i think it will fit once i cut 2 of the tabs off.
41 - 60 of 87 Posts
