Okay first off, all your going to need is a box cutter, a butter knife, and a yard of suede cloth ( I got mine for 10 dollars at Joanns Fabrics cuz their having a 50% off thing.)
First you take you door and lie it down, and take your suede as well. ![]() ![]() Next take your suede and lay it on the door to get an idea of how much you'll need. ![]() Take your butter knife and stick the suede into the little grooves of the door panel and get an idea of how much you can remove. ![]() Once you have an idea, take your box cutter and cut across for the portion you need so the rest dont get in the way. ![]() Once that's done, take your butter knife and reshape it once again. ![]() ![]() While your doing this, it should start to sit in perfect like this. ![]() The arm rest holder thing is the hardest part. You'll have to make a little slit in the suede so you can move it on the side. The arm rest cup thing moves up a little if you tug on it so you can slip the suede in. ![]() Once that's finished, it should start to come out pretty nice. ![]() Again.. use the butter knife to smoothen it out. ALMOST DONE! ![]() And walla! your finished, I didnt use any tape or stick on stuff because the grooves got it to stay tight for me, but The bottom is a little flimsy so you would want to use some 3M tape or something for that. Heres the finished product.
![]() *Injen cold air intake *4-1 Header *Custom 2.5 exhaust w/ titanium tip *Ex head swap *Stage 1 cam *Underdrive pulley *Piggybacked by VAFC II Last edited by lifes_simple; 05-22-2009 at 07:44 PM. |
#3 |
Its one piece, I wish it was removable though =/.
![]() *Injen cold air intake *4-1 Header *Custom 2.5 exhaust w/ titanium tip *Ex head swap *Stage 1 cam *Underdrive pulley *Piggybacked by VAFC II |
#5 |
easier way to do this is to remove the fabric inserts from teh doors, use them as a pattern, cut your suede, and use 3m super trim adhesive spray, permanent and better fit
![]() Pete i like the meat curtains my build thread i <3 pete uıɐƃɐ ʎɐqǝ ɯoɹɟ pɹɐoqʎǝʞ ɐ ƃuıʎnq ɹǝʌǝu ɯɐ ı |
#7 |
Adams way is a more permanent way, the OP's way is good if you are undecided on the color....
#9 |
Do u have power windows and locks?
#10 |
K-Series Legend
A little hint, get some 3M spray adhesive and spray it on the door and fabric and work from on side to the other. On the areas you don't want the fabric to stick add vasoline. Least thats what i did.
RIP to the worlds first ITR K20a, Supercharged 2001 Honda Civic Ex... Totaled 1-20-2010 DIY: Supercharger Install P-Spec Short Shifter Install Oil Catch Can Setup K24a4 Build ![]()
| Tags |
| diy, door, inserts |
