Turbo Oil Restrictor - 7th Gen Honda Forum - The #1 Community for 2001-2005 Honda Civic Enthusiasts
Old 02-22-2013, 04:00 PM   #1
CAVIC
CAVIC's Avatar
CAVIC is an unknown quantity at this point
Total Points: 45,691,309,239.37
Default Turbo Oil Restrictor
I recently replaced all the seals on my head and block including the valve stem seals and headgasket yet I get more than usual bluish smoke at a cold start, more so first time I crank it in the morning (not heavy at all once warm)
been considering a oil restrictor for my turbo, anyone have experience with a restrictor on their setup? came to realize i may have to much oil feed to my turbo which possible may or did damage my turbo seals
Turbo is a Garrett T3 super 60, any info would be appreciated regarding a restrictor as the idea just came to my head and I am slightly clueless about it
ES2 D17 9psi 246hp 216tq
CAVIC is offline   Reply With Quote
Old 02-22-2013, 07:41 PM   #2
j182j
j182j's Avatar
j182j is an unknown quantity at this point
Total Points: 27,516,079,958.32
Milwaukee Brewers Green Bay Packers
I have a restrictor on my turbo, it's just an older small garrett T3. My car would smoke a bit too and I notice it was using a bit of oil. I got it from King Motorsports here is the site http://www.kingmotorsports.com/p-299...-fittings.aspx Since I put that in no more smoke and doesn't use oil. Good luck.
The Black And Green 83!
School of choice: www.uti.edu
j182j is offline   Reply With Quote
Old 02-22-2013, 09:48 PM   #3
CAVIC
CAVIC's Avatar
Thanks for the link, although would you know how well the oil pressure feed with that restrictor is? i fear the issue of starving the turbo from oil as well
i guess my main question is around what is the average turbo feed pressure
Old 02-22-2013, 10:01 PM   #4
j182j
j182j's Avatar
I wouldnt know about how much the pressure is restricted, but I have had mine in for over 2 years and have had no issue with the turbo being starved of oil. Like I said I am running an older Garrett with bushings not ball bearings, if you are running a ball bearing turbo you may want to call up a place like king or a local speed shop and see what they say.
Old 02-22-2013, 11:23 PM   #5
bomerman19
Premium Subscriber
bomerman19's Avatar
bomerman19 is a jewel in the roughbomerman19 is a jewel in the roughbomerman19 is a jewel in the roughbomerman19 is a jewel in the roughbomerman19 is a jewel in the roughbomerman19 is a jewel in the roughbomerman19 is a jewel in the roughbomerman19 is a jewel in the roughbomerman19 is a jewel in the roughbomerman19 is a jewel in the roughbomerman19 is a jewel in the rough
Total Points: 91,379,401,307.54
A pint of bitter.....ill make it a real one someday soon, Thanks alot :-) - Tomj333_EM2
you should always run a restrictor for a turbo what size is up to you but as of this moment I run a journal bearing turbo but my restrictor is the size you would use on a dual ball bearing turbo which is really tiny and I have no issues and have a lot less smoke
cause clint's a lazy bastard my build thread http://www.7thgenhonda.com/forum/showthread.php?t=10229
Originally Posted by DaGriz View Post
Welding it kinda like sex: It must feel good, look good, but the real key is good penetration!
bomerman19 is offline   Reply With Quote
Old 02-23-2013, 07:29 AM   #6
j182j
j182j's Avatar
I just went with what King recomended for my turbo, they are very good guys there.
Old 02-23-2013, 05:26 PM   #7
CAVIC
CAVIC's Avatar
I do plan to run one as the turbo is most likely my cause of oil consumption, not much but visually noticable by blue smoke
I just dont know what oil pressure my turbo should have, Paul if im not wrong you previously had a Garrett T3 super 60? would you know the ideal oil pressure for it, thats really my main question as from there i can look into restrictors or make a regulator to control the oil pressure
Old 02-23-2013, 11:48 PM   #8
bomerman19
Premium Subscriber
bomerman19's Avatar
http://www.verociousmotorsports.com/...il-Filter-4-AN
get this in the 0.030 (black) clean it from time to time call it a day
Old 02-24-2013, 05:54 PM   #9
CAVIC
CAVIC's Avatar
thanks for the link, although I dont have a BB turbo and that .30 in black says its for BB turbos, I am considering getting an oil pressure regulator instead of a restrictor to see where exactly the psi is at
Old 02-25-2013, 02:07 PM   #10
bomerman19
Premium Subscriber
bomerman19's Avatar
no see thats the trick you put an oil restrictor for a ball bearing turbo on a journal bearing turbo and it cuts down on the oil and smoke burning this is what I am running right the moment (on my journal bearing turbo)
