Cranks but wont start - spark issue? - 7th Gen Honda Forum - The #1 Community for 2001-2005 Honda Civic Enthusiasts
Old 01-17-2013, 05:40 PM   #1
a4andy
a4andy is an unknown quantity at this point
Total Points: 1,223.73
Default Cranks but wont start - spark issue?
Alright, I need some help for my GFs car!
When she first got it, it was all fine, then after a few days, the car wouldn't start. It would just crank and crank. And when it did start, the first few seconds the car sounded like it was gulping for gas or gas and would shake.
When I was troubleshooting the issue, I was able to hear the fuel pumps prime, there was gas in the tank, so I checked the sparks. All but one gave an orange spark, so I decided to change all 4 of them.
That worked great for a week, car was running fine and all, but now it went back to the same problem. I checked all spark plugs again and they are all orange/weak once again (these were brand new a week ago). Anyone know what's going on? I am about to get another set of spark plugs to see if it works agin, but even if it does, I have a feeling the same thing will happen in another week.
Car is an 03 Civic LX Coupe
a4andy is offline   Reply With Quote
Old 01-17-2013, 06:19 PM   #2
ricechain
ricechain's Avatar
ricechain is an unknown quantity at this point
Total Points: 18,333.10
Default Re: Cranks but wont start!
Orange spark means weak ignition, could be coils. How many miles on the car?
ricechain is online now   Reply With Quote
Old 01-17-2013, 07:05 PM   #3
a4andy
Car has 135xxx
I just replaced the plugs once again as a temp fix, made sure to test the spark and they all gave a white light just like last time. Car also started.
But I still think the same thing will happen within a few days.
Could it really be the coils even though it isn't giving a weak spark on new plugs?
Old 01-17-2013, 07:25 PM   #4
ricechain
ricechain's Avatar
To be honest Idk thats just were id start also check all fuses and motor grounds especially the ground on the thermostat houseing.
Old 01-19-2013, 03:15 PM   #5
a4andy
All fuses seem okay, where exactly is that ground at?
Old 01-20-2013, 10:28 PM   #6
a4andy
Car has only been driven about 4 times and it seems to be having the old symptoms again. Tested the sparks and they are now turning weak, not white like when I first tested them brand new...
Any help on what it could be....?
Old 01-20-2013, 10:33 PM   #7
MURD3R_ES1
MURD3R_ES1's Avatar
MURD3R_ES1 is an unknown quantity at this point
Total Points: 250,771,839,527.37
heres ur cookie! lol - Greeenie
Los Angeles Lakers Pittsburgh Steelers
what spark plugs are you running exactly ?
any check engine codes ?
might want to check this out also -
http://www.7thgenhonda.com/forum/showthread.php?t=1976
MURD3R_ES1 is online now   Reply With Quote
Old 01-20-2013, 10:53 PM   #8
Maximized4Door
Maximized4Door's Avatar
Maximized4Door is an unknown quantity at this point
Total Points: 10,347,251,080.10
What about swapping the coils around? See if the problem follows the coil?
2004 Honda Civic LX
1983 Cadillac Coupe Deville
Maximized4Door is offline   Reply With Quote
Old 01-21-2013, 12:12 PM   #9
a4andy
O'reilly's gave us NGK Platinums (ZFR6FGP 7100)
No CEL codes, I have one of those bluetooth scanners and my phone isn't giving any faults.
I did that too, all plugs seem to be going weak together, it isn't just 1 spark plug that is doing it.
Old 01-21-2013, 12:24 PM   #10
JDM_Distinkt
JDM_Distinkt's Avatar
JDM_Distinkt is an unknown quantity at this point
Total Points: 8,467.24
No CEL codes, I have one of those bluetooth scanners and my phone isn't giving any faults????
Is that even possible?
Spending money I don't have to impress people I don't know!
ES1
JDM_Distinkt is offline   Reply With Quote
