Oil? Where is it going? - 7th Gen Honda Forum - The #1 Community for 2001-2005 Honda Civic Enthusiasts
Old 01-17-2013, 10:30 AM   #1
NC Kenny
NC Kenny's Avatar
NC Kenny is an unknown quantity at this point
Total Points: 3,906.19
Default Oil? Where is it going?
Okay so I've changed the front seal and valve cover gasket, and I my oil is still 1/2 a quart low after about 2 weeks of driving. Its not a big leak but i can't seem to find it. Car has 139k on it. Its my DD.
Any Suggestions?
NC Kenny is offline   Reply With Quote
Old 01-21-2013, 11:11 PM   #2
Magnemike33
Magnemike33 is an unknown quantity at this point
Total Points: 2,536,349,422.54
Its a Honda. Mine burns oil too. Its either the valve stem seals or the piston rings.
Magnemike33 is offline   Reply With Quote
Old 01-21-2013, 11:20 PM   #3
CAVIC
CAVIC's Avatar
CAVIC is an unknown quantity at this point
Total Points: 47,537,237,091.99
he did not state it was burning and mentioned a leak
since you did replace the crank seal also known as the front seal (along with the timing belt package, i would hope) its probably the rear main seal, which is attached to the block behind the flywheel or tq converter on a AT, otherwise possible camshaft seal
willing to bet its the rear main seal, have fun
ES2 D17 9psi 246hp 216tq
CAVIC is offline   Reply With Quote
Old 01-22-2013, 08:08 PM   #4
NC Kenny
NC Kenny's Avatar
Thanks ill check it out.
Old 01-22-2013, 09:38 PM   #5
Maximized4Door
Maximized4Door's Avatar
Maximized4Door is an unknown quantity at this point
Total Points: 12,613,219,860.24
My rear main seal went, didn't leak as much as yours is, but still substantial.
2004 Honda Civic LX
1983 Cadillac Coupe Deville
Maximized4Door is online now   Reply With Quote
Old 01-22-2013, 10:54 PM   #6
Black_Label_Civic
Black_Label_Civic is an unknown quantity at this point
Total Points: 2,627.14
mine was leaking too. it was the oil pan gasket.
Black_Label_Civic is offline   Reply With Quote
Old 01-25-2013, 08:56 PM   #7
OhhBeKay
Moderator
OhhBeKay's Avatar
OhhBeKay is on a distinguished roadOhhBeKay is on a distinguished roadOhhBeKay is on a distinguished roadOhhBeKay is on a distinguished roadOhhBeKay is on a distinguished road
Total Points: 30,749,104,454.47
you have an ex via your other posts.
they dont have an oil pan gasket.
OBK's Build Journal
OhhBeKay is offline   Reply With Quote
Old 01-26-2013, 12:09 PM   #8
clutch05ex
clutch05ex's Avatar
clutch05ex is an unknown quantity at this point
Total Points: 9,008,135,614.04
^Honda Bond is used as a gasket on the EX. Sometimes it wears out or forms leaks. Mine's bad and loses 3/4 of a quart every 2k-3k. I just haven't had the time at work to redo it.
NorCar dreamin'.....
clutch05ex is offline   Reply With Quote
