#1 | |
So, I got bored and I searched the word 'stance' on these forums.
Ran into this quote on the 'Stance Help!' thread http://www.7thgenhonda.com/forum/showthread.php?t=27146 Quote:
I know coilovers are preferred for a more fuller suspension swap, but is there anything else needed besides camber kits?
#2 |
yes
i would not consider my self slammed but i have : rear camber arms, camber plates, 4 camber bolts, coils, fenders rolled and pulled a little. my diver side axle hits every so often.
#3 |
That depends, if you want a clean, lowered car, all you need is coilovers, camber bolts, and camber kits.
If you're looking to be slammed, I mean em2cody, obk, Dean Sanchez, hondarules, and 1sickes1 slammed, your going to need at least 16's, frame notch, shorter/inverted tie rods, some way to get more low in the front(shorter springs, extended top hats) lower offset wheels, fender roll definitely, maybe fender pull, in some cases a frame notch, and stretched tires. One of my favorite setups is OBK's. His tires have no stretch but he still has good fitment. Also, keep in mind that slammed does not necessarily mean flush. You can be slammed on 15's or high offset wheels but your wheels will be look sunken into the fenders. em2cody ![]() obk ![]() dean sanchez ![]() hondarules ![]() 1sickes1
K, cool. That should be good. I just wanna lower my car on the OEM rims for a bit and perhaps invest in some nice ones.
#6 |
Cool. Imma just use the special edition rims
#7 | |
plus all sorts of stuff that you will find after you lift the car, such as worn-out bushings, endlinks, ball joints, torn boots, etc, etc so if you are just doing a small to mild lowering, have a buffer in the bank, at the least for the sway bar endlinks and the LCA bushing (the most likely to cause trouble )
02 EX Coupe Eibach/KYB AGX, Progress RSB, Camber kits AEM CAI (water sucker ), Crower Stage 101 Miata Hard-S, FM/FCM goodies 95 R-pack Miata |
#8 | |
#9 |
You might not have to for a pretty long while. You might have lowest mileage em2 on this site. But Energy suspension bushings give you better ride quality. You should also try to find a bigger rear sway bar like the 05-06 rsx-s 21mm bar. You don't need one but less body roll=less rubbing if your tires are really close to your fenders.
#10 | |
