New Rims, Will Tires Fit Without Rubbing - 7th Gen Honda Forum - The #1 Community for 2001-2005 Honda Civic Enthusiasts
Old 01-03-2013, 04:30 PM   #1
cb450sc
cb450sc is an unknown quantity at this point
Total Points: 2,255.95
Default New Rims, Will Tires Fit Without Rubbing
Yes I have done a search and can't seem to find anything. I have purchased a 2005 Civic (Canadian) Special Edition. It is just a base model with air conditioning. I have purchased 2005 Si rims for it, I believe they are called "fat fives". The worn out tires on these rims are 195/60R15. I want to have as smooth a ride as possible over the bumps around here without having the tires rub. Can I put 195/65R15 on these rims without rubbing?
cb450sc is offline   Reply With Quote
Old 01-03-2013, 04:41 PM   #2
Seus'EM2
Seus'EM2's Avatar
Seus'EM2 is an unknown quantity at this point
Total Points: 55,697,420,912.36
use 205/50/15.
Seus'EM2 is offline   Reply With Quote
Old 01-03-2013, 08:58 PM   #3
cb450sc
I want to have as much sidewall as possible not less.
Old 01-04-2013, 03:58 PM   #4
rob3662
rob3662 is an unknown quantity at this point
Total Points: 43,917,036,429.26
205/60/15 will fit fine, so 195/65/15 should work too, they are only around a 1/4" taller.
rob3662 is offline   Reply With Quote
Old 01-06-2013, 07:10 AM   #5
cb450sc
Thanks
