Turbos almost done, need help ?!?!? - 7th Gen Honda Forum - The #1 Community for 2001-2005 Honda Civic Enthusiasts
Old 12-29-2012, 04:33 PM   #1
Black341Ops
Black341Ops's Avatar
Black341Ops is an unknown quantity at this point
Total Points: 19,117,279,162.01
Default Turbos almost done, need help ?!?!?
So turbo install and all that crap is almost done , my tuner called me today and asked if i could find him a fuel rail that would fit my car. So my question is can i just use on that would fit the srt injectors and fab up some tabs to mount it? or something that would fit for the d17 injector plate? Cause the d16y8 mani swap just seems like a hassle for a ex when im this close to finishing it up. Any suggestions at this point would be greatly appreciated, trying to get the car back. Thanks
Black341Ops is offline   Reply With Quote
Old 12-29-2012, 05:28 PM   #2
CAVIC
CAVIC's Avatar
CAVIC is an unknown quantity at this point
Total Points: 45,691,309,226.37
Dont think any fuel rail is interchangable within the D17 besides one off any of its models
If your issue is your injectors being to tall not allowing your fuel rail to bolt down, you will need to get extended studs for the fuel rail or use a bolt with the same thread and use spacers with washers to hold it down
ES2 D17 9psi 246hp 216tq
CAVIC is offline   Reply With Quote
Old 12-29-2012, 05:52 PM   #3
Black341Ops
nah the injectors fit he just didn't want to hack up the fuel rail to do the return fuel setup and the aem fpr, but he said he'll just go that route hes been looking for a diff way all day like me haha
Old 12-31-2012, 07:32 PM   #4
JoSoTurbo
JoSoTurbo's Avatar
JoSoTurbo is an unknown quantity at this point
Total Points: 19,499,656,600.36
He is gonna have to cut the fuel rail. Your only option on using a different fuel rail is to swith to the d16 intake manifold. Then your options are open to the aftermarket stuff. He should be able to tap the other end and weld a bung on it. That is by far the cheapest option for you to do.
JoSoTurbo is offline   Reply With Quote
Old 01-01-2013, 09:49 PM   #5
Black341Ops
Yes that's what he's doing now Ty all
