Clogged heater core? - 7th Gen Honda Forum - The #1 Community for 2001-2005 Honda Civic Enthusiasts
Old 12-21-2012, 01:59 AM   #1
Black_Label_Civic
Black_Label_Civic is an unknown quantity at this point
Total Points: 2,488.14
Default Clogged heater core?
i usally let the engine warm up before using the heater. but recently ive noticed even with the engine warmed up around 170F the heater will work good then get cold. if i turn the heater off for a couple of min. it will be hot again then get cold. its done it at 185F too. after awhile the heater will start working well without issue. is my heater core clogged or bad thermostat or waterpump?
- Mike
Black_Label_Civic is offline   Reply With Quote
Old 12-21-2012, 07:36 AM   #2
morerice
morerice's Avatar
morerice is an unknown quantity at this point
Total Points: 5,751.45
could be a bad waterpump, mine was bad cause intermittent poor flow and heat was cutting in a out at operating temp
01 Civic Si(EX Coupe)-winter beater-slow
12 Fiat 500 Sport-Bolt-ons-d.d gas miser
04 SRT-4 GT35R-600whp-Toy-10.8sec 1/4mile
K&H Rad - Ontario C.S.F Performance Rad Dist.416-266-7777 dynojet on site.
morerice is offline   Reply With Quote
Old 12-21-2012, 01:09 PM   #3
mikereynolds9
mikereynolds9 is an unknown quantity at this point
Total Points: 13,212.36
Yea mine has been doing the same thing lately car will warm up and only blows heat when im driving. But when I stop it blows cold air. didnt know what to make of it
mikereynolds9 is offline   Reply With Quote
Old 12-21-2012, 03:51 PM   #4
morerice
morerice's Avatar
yea... have your waterpump checked
Old 12-21-2012, 07:39 PM   #5
Greeenie
Greeenie's Avatar
Greeenie has a reputation beyond reputeGreeenie has a reputation beyond reputeGreeenie has a reputation beyond reputeGreeenie has a reputation beyond reputeGreeenie has a reputation beyond reputeGreeenie has a reputation beyond reputeGreeenie has a reputation beyond reputeGreeenie has a reputation beyond reputeGreeenie has a reputation beyond reputeGreeenie has a reputation beyond reputeGreeenie has a reputation beyond repute
Total Points: 346,791,516,006,972.44
Nothing says good job like the gift of fish! - speedfoos IA 08' Crew w00t! - Mralbino I. Like. You. - Mralbino thanks fukker - rj - DEIJ I got you some Fireside Nut Brown for ya - Mralbino
Have some puffs with aloe, Hope you get to feeling better! - Alpha5'sotherwoman i owe ya a beer when we meet up at IA for the help on the vic. - Dhezee thanks for listening to my rant and talkin to him!  appreciate it man!!   bryce - bryce023 Thought you might need some of this old man ;). - Vilex b-day - taylorsherk
Awesome birthday gift to amyhates! - aliefjoker
New York Yankees Dallas Cowboys
check ur damn fluid level, id bet coolant is low. occam's razor
Pete i like the meat curtains
my build thread
i <3 pete
uıɐƃɐ ʎɐqǝ ɯoɹɟ pɹɐoqʎǝʞ ɐ ƃuıʎnq ɹǝʌǝu ɯɐ ı
Greeenie is offline   Reply With Quote
Old 12-22-2012, 08:05 AM   #6
morerice
morerice's Avatar
^ yes check your coolant level first, but coolant system is suppose to be a sealed/pressurized system except for the overflow bottle, there for your level shouldnt get really low unless you have a leak. i.e radiator, waterpump, hoses, etc..
Old 01-04-2013, 04:10 PM   #7
jdm2u
jdm2u is an unknown quantity at this point
Total Points: 1,549.54
x3 check coolant level if it is low would start to check for a leak if fluid is full i would go cheap route first and replace thermostat be sure you properly bleed system!
jdm2u is offline   Reply With Quote
Old 01-07-2013, 03:18 PM   #8
vtec9588
vtec9588's Avatar
vtec9588 is an unknown quantity at this point
Total Points: 104,964,048,965.03
Honda has a bulletin out on this. Its air getting trapped in the heater core. Try raising the front of the car while filling with coolant to get the air out. Mine was just doing this.
vtec9588 is offline   Reply With Quote
Old 01-17-2013, 03:39 PM   #9
aznnp77
aznnp77 is an unknown quantity at this point
Total Points: 1,847,610,721.97
When I had about 100k miles it was winter time, and my heater would not get hot unless the car was moving. I chose to ignore it. My belief is that it was something as simple as a stuck thermostat.
By 120k miles my headgasket had blown, probably from my ignorance during that winter. Get it checked out and fixed so you don't cause some major problems.
aznnp77 is offline   Reply With Quote
Old 01-18-2013, 10:36 AM   #10
Black_Label_Civic
coolant level is good. im going to be replacing the timing belt so im going to throw in a new water pump while im in there. ill probably get a new thermostat too sense there like 10 bucks. im going to change the coolant as well.
