Keyless entry flashing parking and tail lights dont work and instrument backlight off - 7th Gen Honda Forum - The #1 Community for 2001-2005 Honda Civic Enthusiasts
Go Back   7th Gen Honda Forum - The #1 Community for 2001-2005 Honda Civic Enthusiasts > General > Electrical
7thGenHonda.com is the premier Honda Civic Forum on the internet. Registered Users do not see the above ads.
Old 05-27-2010, 10:21 AM   #1
shippy132
shippy132 is an unknown quantity at this point
Total Points: 1,000,003,511.97
Default Keyless entry flashing parking and tail lights dont work and instrument backlight off
Hi Guys here is my situation,
I was driving on the highway yesterday pulling a small trailer and all of a sudden my speed/tach/fuel backlight turned off. When i got home i noticed that my keyless entry will lock and unlock the doors, but the my front parking lights do not flash or my tail lights don't flash when i lock or unlock the car. Usually when i unlock the car there are 2 beeps from inside the car and you can hear a relay clicking to turn the lights on and off but now i can't hear it. Every other light and function of the car is working.
I don't understand how the instrument backlight and the keyless lights are related, HELP!!
shippy132 is offline   Reply With Quote
Old 05-27-2010, 10:39 AM   #2
burton-
burton-'s Avatar
burton- is an unknown quantity at this point
Total Points: 1,372,871,970.03
Check fuses.
To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts.
burton- is offline   Reply With Quote
Old 05-27-2010, 10:47 AM   #3
CraigW
CraigW's Avatar
CraigW is an unknown quantity at this pointCraigW is an unknown quantity at this point
Total Points: 1,752,769,062,984,102.75
"small lights" fuse in under hood box.
CraigW is offline   Reply With Quote
Old 05-27-2010, 11:00 AM   #4
BIRDY
BIRDY's Avatar
BIRDY is an unknown quantity at this point
Total Points: 9,187,989,826.28
check the fuses. And for your alarm, I had the same problem last week. I noticed that when I locked it, it locked up fine, but the alarm didnt beep and my lights didn't flash.
To solve that problem I did a sequence putting my key into the ignition, putting it in and out 2-3 times. I hope you understand what I'm saying lol. Your car may be in what is called "Valet Mode".
Lemme know if you still don't understand what I'm saying. I'll then try to get a pic up of the manual I used to solve this problem.
My For Sale Thread
BIRDY is offline   Reply With Quote
Old 05-27-2010, 11:09 AM   #5
Bis
Bis is a jewel in the roughBis is a jewel in the roughBis is a jewel in the roughBis is a jewel in the roughBis is a jewel in the roughBis is a jewel in the roughBis is a jewel in the roughBis is a jewel in the roughBis is a jewel in the roughBis is a jewel in the roughBis is a jewel in the rough
Total Points: 1,272,911,661.63
Nor*Cal and Central Valley 7thgen member FTW! - wickedbautista For being a cool kat! Starting the 7thGenCrew Cen*Cal - Limestand late night stories! - MimiEM2 thanks for the help on the 5 lug conversion - wickedbautista you still have to read me the book...where the wild things are - wickedbautista
x2
had this problem last week.
Bis is offline   Reply With Quote
Old 05-27-2010, 11:17 AM   #6
shippy132
Default But guys
But guys, all my small lights work except for the instrument cluster lights. Is this fuse still the problem??
Also, thanks Birdy I will try the key in and out thing when i am on my lunch, i think i know what you mean
Old 05-27-2010, 11:21 AM   #7
burton-
burton-'s Avatar
Why don't you just go and check? Pop your hood, check the fuse. Then you will have your answer as to if it's the small light fuse that's blown or not.
Old 05-27-2010, 11:28 AM   #8
shippy132
Ok good idea, i will check on lunch
Old 05-27-2010, 12:13 PM   #9
shippy132
I tried the procedure to get the car out of valet mode and it did not work. I'm not sure if it is in valet mode because the horn honks when i press the lock button twice, the only thing is that the lights do not flash.
I looked under the hood for the small lights fuse and did not know which one it is. I am going to look up what fuse it is now.
Old 05-27-2010, 12:42 PM   #10
cyberphox
cyberphox is an unknown quantity at this point
Total Points: 2,536,357,091.21
I was thinking Fuses right away too...
cyberphox is offline   Reply With Quote
Tags
backlight, keyless, relay, security
Powered by vBulletin® Copyright ©2000 - 2017, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
