7thGenHonda.com - The #1 Community for 2001-2005 Honda Civic Enthusiasts
Old 07-09-2007, 10:28 PM   #1
RHCP0801
Administrator
RHCP0801's Avatar
RHCP0801 has disabled reputation
Total Points: 122,724,776.29
You fukker, approved... IA 08' crew! - Mralbino thanks for the lesson!! yea, its personal! - real adam - greeen01civic4d
New York Mets
Default DIY: Rear Drum Brakes to Rear Disc Brakes
ok first off this is not an easy mod, you need to know what you are doing and do it very carefully, you are working with a part of your car that helps you stop and if not done correctly this can be a disaster
now on to the info
The parts you are going to need are a set of EP3 rear discs (02-03 Honda Civic Si) if you wanna get it all seperate which i dont suggest doing since it will be a pain and cost a lot more. I picked up my set that came with everything (EP3 ebrake cables, rear calipers, rotors, brake lines, master cylinder and proportioning valve(optional but suggested) spindle's(knuckle) and various clips and what not for $220 shipped. Go to a junkyard and ask for a rear disc setup off an 02-03 civic si and thats what you will need right there but make sure it comes with everything
1. Remove your wheels and remove the brake line in the upper corner of the wheel well, no need to remove the bracket, just remove the brake line with a 10mm wrench, now i used a line wrench to do this which made this much easier but be very careful cause the nut can strip easily.
2. Go into the car and take apart the center console until you reach your ebrake cables, loosen the adjustment nut and pull out the old ebrake cables and unbolt the 3 bolts that hold it to the underside of the car. Not all the mounting brackets on the si cables will match up so you will have to either drill a new hole and screw it in or zip tie it up under the car. The new cables are also shorter and its tough getting them to fit in the carriage so you will need some muscle to get them in but they do fit, remember attach them to the caliper first
3. Now your gonna want to remove the drum so you can see inside the brake assembly, remove the bolts on the back of the drum that hold the ebrake cable and brake lines, i believe they are 10 and 12mm bolts, its just about 5 or so, once all those bolts are out its time to remove the wheel sensor, spray a lot of rust penetrant or pb blaster on this thing cause they did not budge on my car and i ended up breaking one and it costs $40 from the dealer, if you dont replace them your abs light will be on and of course...you wont have abs in the car at all....once the abs light is on it affects the whole system. The sensor looks like this, this would be the part facing you when you remove the drum, it fits in a hole right in the middle of the drum behind the hub
this is it broken, its a magnet basically
and this is where it plugs into just incase yours breaks and you need to replace it, the ones that come with the spindles from the si dont work
4. Remove the 3 bolts that hold the knuckle to the car, they are all 17mm i believe and its easy, just use a ratchet and take them out, support the knuckle with a jack so when you take the bolts out it doesnt fall. The one bolt has a cam nut on it for alignment, that doesnt need to be spun off, just pull it off
5. install everything back on the car in reverse order, brakes lines, brackets calipers, pads, rotors...etc etc
6. Install the ebrake cables, feed them through the floor and bolt them to the floor pan, pull the line under the knuckle and attach to the spring like device on the caliper, its a lot easier to install them if you attach them to the caliper first than to the handle just make sure you loosened the adjustment nut as much as possible cause it wont be easy. Connect the left cable first than the right one
here is a picture of the caliper with the ebrake cables installed, feed them through the bracket with the hole in it first and than up to the spring with the lever on it
7. Make sure everthing is tight and no brake fluid is leaking, bleed them and take it for a drive, go easy at first and gradually get harder on them
this took me about 2 hours or maybe a little less to do with air tools and a lift but it shouldnt take more than 4 or so without them, hardest thing to do was the ebrake cables
8. all done :woot:
QUICK TIP - DRAW A LINE WITH MARKER AROUND THE ROTOR TO SEE IF THE PADS ENGAGE, DRIVE IT AND IF THE MARKER IS GONE THAN THEY DID, IF NOT THAN YOU HAVE A PROBLEM
I ALSO SUGGEST YOU CHANGE OVER YOUR MASTER CYLINDER AND PROPORTIONING VALVE AS DISC BRAKES NEED MORE PSI TO ENGAGE THAN DRUM BRAKES. DRUM BRAKES USE ABOUT 500 PSI AND DISC BRAKES USE ABOUT 1200PSI. THE MASTER AND PRO VALVE SWAP RIGHT OVER, JUST MAKE SURE YOU BLEED YOUR BRAKES WELL AFTER DOING SO. THE PARTS ARE ALSO CHEAP BRAND NEW.
MASTER AND PROPORTIONING VALVE ARE NOT NEEDED BUT THEY HELP IN PEDAL FIRMNESS AND PREVENTING FRONT WHEEL LOCKUP
any questions just let me know
**The post above should be taken as the opinion of RHCP0801 and should not be viewed as a representation of 7thgenhonda.com**
Originally Posted by Steven View Post
my bitch ass will never be at IA
RHCP0801 is offline   Reply With Quote
Old 07-09-2007, 10:45 PM   #2
TransformedBG
K-series SC master!
TransformedBG's Avatar
TransformedBG has a reputation beyond reputeTransformedBG has a reputation beyond reputeTransformedBG has a reputation beyond reputeTransformedBG has a reputation beyond reputeTransformedBG has a reputation beyond reputeTransformedBG has a reputation beyond reputeTransformedBG has a reputation beyond reputeTransformedBG has a reputation beyond reputeTransformedBG has a reputation beyond reputeTransformedBG has a reputation beyond reputeTransformedBG has a reputation beyond repute
Total Points: 5,045,372.57
dont leave, ur gonna make me cry, i dont want to be the only green - greeen01civic4d
Troop and Military Support - Amber Alert - Bladder Cancer - Endometriosis - Equality - Liver Cancer - Liver Disease - Missing Children - POW/MIA - Spina Bifida - Suicide - TransformedBG
This is how diys should be.. vs links.. as we do things make new ones
m not active enough on the forums apparently so i have to talk on every single thread to up my post count!
DIY:
Supercharger Install
P-Spec Short Shifter Install
Oil Catch Can Setup
K24a4 Build
TransformedBG is offline   Reply With Quote
Old 07-09-2007, 11:25 PM   #3
CHRIS
Administrator
CHRIS's Avatar
CHRIS has disabled reputation
Total Points: 152,299.39
Detroit Tigers Michigan State Detroit Red Wings
^yeah well untl we make new ones we have to use links...not my doing
nice write up adam
*The post above should be taken as the opinion of "CHRIS" and should not be viewed as a representation of 7thgenhonda.com**
CHRIS is offline   Reply With Quote
Old 07-09-2007, 11:49 PM   #4
civicman1988
civicman1988's Avatar
civicman1988 has a spectacular aura aboutcivicman1988 has a spectacular aura aboutcivicman1988 has a spectacular aura aboutcivicman1988 has a spectacular aura aboutcivicman1988 has a spectacular aura aboutcivicman1988 has a spectacular aura aboutcivicman1988 has a spectacular aura aboutcivicman1988 has a spectacular aura aboutcivicman1988 has a spectacular aura about
Total Points: 2,680,802.73
thanks for lookin out, u need a gift! - Greeen - greeen01civic4d Good work, you need another gift - bjanzen Thought this would help get you up and running with your project - bjanzen
sweet did u get everything brand new? If so where?
civicman1988 is offline   Reply With Quote
Old 07-10-2007, 12:01 AM   #5
RHCP0801
Administrator
RHCP0801's Avatar
New York Mets
na i got it all used, all from ephatch.com
if you want this stuff brand new i hope you have money, dealer charges like $200 just for the knuckle...it would probably cost over a grand if you bought it all new...no point in that, just go to a junkyard
Old 07-10-2007, 12:43 AM   #6
ant206
thehighestsociety.com
ant206's Avatar
ant206 is an unknown quantity at this pointant206 is an unknown quantity at this point
Total Points: 49,195.55
im guessing this was done on an ex? since you got abs. anything differnt since the lx dont got abs?
PROFRESHH.PNOYFUKKERZ.BB CREW.7THGEN [OR/WA]
No idea's original, there's nothin new under the sun It's never what you do,but how it's done
ant206 is offline   Reply With Quote
Old 07-10-2007, 01:08 AM   #7
CHRIS
Administrator
CHRIS's Avatar
how big of a difference do u notice?
Old 07-10-2007, 08:04 AM   #8
Punkingcivic
Punkingcivic's Avatar
Location: 805 - So.Cal, Oxnard, Ventura County, North of Los Angeles
Punkingcivic has a spectacular aura aboutPunkingcivic has a spectacular aura aboutPunkingcivic has a spectacular aura aboutPunkingcivic has a spectacular aura aboutPunkingcivic has a spectacular aura aboutPunkingcivic has a spectacular aura aboutPunkingcivic has a spectacular aura aboutPunkingcivic has a spectacular aura aboutPunkingcivic has a spectacular aura aboutPunkingcivic has a spectacular aura about
Total Points: 287,783.08
yeah all new it is like 600+ for the setup I think
Originally Posted by Punkingcivic
Life is like a toilet, always full of shit. Some people deal with the shit and let it go and others get shitty holding on to it.
Punkingcivic is offline   Reply With Quote
Old 07-10-2007, 08:31 AM   #9
civicman1988
i am looking right now for them. Also did u know a big difference?
Old 07-10-2007, 09:12 AM   #10
Suzy Q
Suzy Q's Avatar
Suzy Q is an unknown quantity at this pointSuzy Q is an unknown quantity at this point
Total Points: 2,044,485.87
You can has rose? - Mralbino You can has latte - Mralbino "S" For Suzy! - Mralbino
Breast Cancer - Birth Parents - Suzy Q
Brazil New York Yankees Louisiana State New Orleans Saints
there is a difference for those w/o abs (i don't know what exactly)
but i seen a thread about it on civicforums
iPhone Krew | Asshole #3
Suzy Q is offline   Reply With Quote
Tags
brakes, disc, diy, drum, rear
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
