#92 | ||
I should stop posting
Quote:
Quote:
At least it's fairly easy to get at the timing belt, hard part is getting the crank pulley off and putting the new belt on correctly.
#93 | |
Member
![]() Total Points: 1,345,872,953.69 |
It was alot easier "back in the day" when you just used a deep well socket and then rotated the breaker bar til it rested against the frame- pop the starter and your in..Now I use the crank pulley "holder with a 24" breaker bar and a 3/4 drive Torque wrench turned up to 300 Ft/Lbs.
Quote:
'04 Accord EX, 1994 Ford F350 IDI turbo, '05 Mariner. Also do powdercoating:http://s420.photobucket.com/albums/p...Powdercoating/
#94 |
I'm getting a bit paranoid because my '03 only has 65k miles but it's 9 years old already. I read somewhere that the tb replacement should be at 110k miles or 7 years. How true is this?
03 civic lx 5 speed. Stock for now 06 Mazdaspeed6. Some mods. |
#95 | |
Quote:
id say do it asap, rather be safe then sorry.
#96 |
That's 10k over schedule. No wonder it broke.
#97 |
Got mine done a few weeks ago. I don't really have to worry about much more for a while.
#99 |
Member
Just using the seal on the water pump. I put some straight silicone on it but it was a light coat... My civic was totaled about 180K and I never had a leak.
My Timing Belt DIY My Coolant Flush DIY "If it's so essential, ask yourself why you've been able to live without it before now." Try doing something nice for a total stranger, then look back at your car. Notice that the good feeling you get from helping lasts all day, but you constantly have to put stuff on your car to feel better. Good Thoughts, Good Words, Good Deeds |
#100 |
Got a question about TDC around step 23 for reddawnman
Threaded new timing belt, and noticed cam is TDC, but crank is almost TDC. Could have moved while threading. Update: Reusing old tensioner. Before belt came off, cam and crank were at TDC. After belt was installed, both were still at TDC. If reusing the same tensioner, be sure to remember to remove the tension from it. When turning the crank to set the belts, the tension moved the crank pulley off TDC. At this point looking into rotating the crank to TDC, then removing the belt, then turn the cam to up TDC, then put the belt back on. Would both positions re align if the tension were to be removed without removing the belt? Last edited by tragedy; 01-14-2013 at 09:20 PM. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Tags |
| belt, diy, replacement, timing |
| Thread Tools | |
| Display Modes | |
