#211 |
#213 | |
Quote:
Toaster i think its safe to say with ur fully built d17 with the IM and some supporting mods you can get into the 300s easily I just wanted to give a big thanks to everyone who has helping me through out my build Dj for answering all my calls regarding turbo issues, couldnt have done it without you!! Sam for hooking up most of the kit parts, bryan for also hooking up my second half of parts for the build, speedfoos and bomerman for their suggestions and creating all sort of diy and diagrams and everyone else i have bought parts from towards my build, thank you all
![]() ES2 D17 9psi 246hp 216tq |
#214 |
#215 | |
Quote:
little update on the car, got a leak from what seems to be coming from the sandwich plate, i replaced the sandwich plate gasket that mates to the block, checked right now and still leaking ![]() also seem to have a hard time shifting into the next gear at high RPMs since i got a heavy duty clutch/pressure plate, so i picked up a new clutch master and slave cylinder along with a SS clutch line ![]() hopefully this helps the issue otherwise i believe it could be the forks inside the trans, doubt its the syncros since it happens in every gear only above 6k rpm
#219 |
Is that a Techna-Fit line? Cor-sport has them for $32 with free shipping. Or are those crap? I am probably just dumb. Your line replaces everything including the stock hard lines. Right? Not just the small rubber section.
#220 | |
Quote:
this was the highest quality they had and 50 bucks for it on the spot with the correct fittings, had to do it And yes replaces the whole hard line, since I did the 5spd conversion my hard line looks stupid, contemplating leaving the rubber hose for flexibility, but i might just go SS line all the way, what do you think?
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
