Low Presure Budget Turbo Kits? - Page 8 - 7th Gen Honda Forum - The #1 Community for 2001-2005 Honda Civic Enthusiasts
7thGenHonda.com is the premier Honda Forum on the internet. Registered Users do not see the above ads.
Reply
Old 12-19-2012, 09:20 PM   #71
Dee
Dee's Avatar
Dee is an unknown quantity at this point
Total Points: 13,685.33
Default
Quote:
Originally Posted by pacotaco View Post
the bypass valve is the piece of metal thats on the side of the compressor housing. the wastegates work just fine on mitshu turbos. i push 26 lbs, and ive spiked at 32 with no issues.
alright sounds good shouldnt have any problems since ill probably be maxing at only 10-12 lbs
Get the facts first...Then distort them as you please
Turbo Build Thread............Pixel Car Done By Me
Dee is online now   Reply With Quote
Old 12-31-2012, 07:44 PM   #72
JoSoTurbo
JoSoTurbo's Avatar
JoSoTurbo is an unknown quantity at this point
Total Points: 19,499,656,587.36
Default
best of luck man
JoSoTurbo is offline   Reply With Quote
Old 01-01-2013, 08:57 PM   #73
Black341Ops
Black341Ops's Avatar
Black341Ops is an unknown quantity at this point
Total Points: 18,742,430,952.49
Default
get a gt28 nothing bigger will fit with the hks manifold unless u mod more thing do a half rad or get rid or p/s, im going to be posting up some more pics on my build , prob friday
P.S. the 14g and 16g off dsm wont fit with that manifold
Black341Ops is offline   Reply With Quote
Old 01-01-2013, 09:00 PM   #74
pacotaco
marshmallower
pacotaco's Avatar
pacotaco is an unknown quantity at this point
Total Points: 8,658,041,712.20
Default
Quote:
gt30s can be fitted up to a t25 fitting.
"research has shown that Saab drivers are the best educated people on the roads" J. Clarkson
I rule your internet...
pacotaco is offline   Reply With Quote
Old 01-01-2013, 09:45 PM   #75
Black341Ops
Default
Sure they can but you'd still be havering to do some more modifications, removing rad support between the 2 fans maybe even getting slim rad fans and prob more. Basically I'm saying as for space there is not much to work with there unless u want to mod more stuff..
Old 01-02-2013, 05:36 PM   #76
pacotaco
marshmallower
pacotaco's Avatar
Default
yeah but in his case he does not need anything bigger than a gt28. i stick with my suggestion of picking up a saab td04hl-15g or a td04l-14t or a volvo hl turbo. more than enough to break 250.
Old 01-02-2013, 06:32 PM   #77
Black341Ops
Default
Regardless he's be spending more on fab and modding one of them than just getting a gt28 and I mean he could go smaller like a gt25 and would be fine too up to him though
Old 01-02-2013, 06:52 PM   #78
pacotaco
marshmallower
pacotaco's Avatar
Default
What modding would need to be done... it should bolt up no different than any garret. infact the saab ones are clocked perfectly for this setup.
were talking about a reliable turbo that can be picked up for 200-400 bucks, a gt28 is going to be about 900 dollars, and t25s and 28s usually run 300-600 and the mitshs can handle more boost and put down more power.
Old 01-02-2013, 07:12 PM   #79
Dee
Dee's Avatar
Default
all im looking for is a turbine with decent spool time (i know dual abll is the best route for this but not spending a grand on jsut turbine) and something that should just bolt on without any or much fab. if anything i can buy slim fans and smaller radiator if i have to but when its not creating that much boost shouldnt be that big but w/e. also if i end up buy CAvics manifold ill need a t3 footing
Old 01-02-2013, 07:31 PM   #80
pacotaco
marshmallower
pacotaco's Avatar
Default
Quote:
not even, my td04 spools at 2100 a gt28 would never spool that early. if you get a t3 then a t28 or gt28 will be out of the question because they are t2 or t25 flange, and its not worth it to spend the money to buy a larger housing. if your getting a t3 just get a td04 16t or 15g from a volvo. they are small and innexpensive turbos with great spool time
Sponsored Links
Advertisement
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, vBulletin Solutions, Inc.
7thgenhonda.com is in no way affiliated with or a part of Honda Motor Co.
